[SOLVED] Missing source when conecting bus line to mux
Hugo17
Junior Member level 1
When I connect "MyMux2" with a bus-line to the ADCdriver input (see picture) I get error messages like:
"Error (12009): Node "Misc:b2v_inst|data_mymux2_2x1" is missing source".
I share the same bus line coming from MyMux1 but here I do not get an error.
Does someone know how to solve this problem?
Thanks!
The source of the bus is numbered with 1 to 3...and 4 to 10.
But at the destination it is numbered 0 to 10.
So number 0 at the source is missing.
Define number 0.
Klaus
Hello
I think I found the problem. I mismatched inputs with outputs. This means that MyMux has inputs while I was trying to connect those signals with the INPUT signal islv_adc_data.
Now I changed the PMOD_J4 and PMOD_J5 to bidirectional signals. Unfortunately I get this error message when compiling:
Error (13076): The pin "PMOD_J4[1]" has multiple drivers due to the non-tri-state driver "clk"
PMOD_J4[1] is connected to the signal osl_adc_clk which is an output. How can I avoid this problem?
Thanks in advance
