sharkies
Member level 5
Hey guys,
I have couple MIMcap arrays for my design.
I have very little routing going through the MIMcap array and if I run chip-level DRC, it gives me density errors.
How do people get away with this error? Do you waive them?
The PDK shows that nothing should be routed underneath the mimcap.
Also, if I decide to put in dummies using the script, dummies will be all over the place.
If I put in dummies under each unit MIMCAP manually to maintain symmetry, I still think this will affect linearity.
The errors that pop-up are local density rules for M1~M6.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
There's also a PO density rule under each MIMCAP as well... I need to put in PO manually to clean this just like the metal density rules. Can I just get the PO and the metals waived?
Does anybody have experience with this(I understand this is process dependent)? or a general guidline?
any clue? I'm kinda reluctant to put in anything below the MIMcap structure.
