mikroc/proteus problem
masab_ahmad
Member level 1
Pakistan
Hi all,
I made a few codes on MikroC and used proteus to see the simulation. I am using a pic16f877a microcontroller. I firstly made this simple code, which didnt work in proteus:
void main()
TRISC = 0 ; // PORTC as outputs
PORTC = 0 ;
PWM1_Init(40000);
PWM1_Start();
while(1)
PWM1_Set_Duty(200);
Then I made this one, which gave me some strange waveforms( unwanted), at the CCP1 pin:
void main()
PORTC = 0 ;
while(1)
PWM1_Init(40000);
PWM1_Start();
PWM1_Set_Duty(200);
I don't understand what went wrong, the first code should have worked! I think proteus is the problem here, plz help....
Zip and upload your Proteus and MikroC files, so that one of us can examine it.
BigDog
ANSEL = 0; // Configure AN pins as digital
ANSELH = 0;
C1ON_bit = 0; // Disable comparators
C2ON_bit = 0;
ANSEL AGAIN!!!
files attached, i also simulated the attached stuff on another simulator, The RealPic Simulator, and it all works perfectly on it....
  • pic16pwm.rar
