mikroC compiler problem
oday_albadarneh
Newbie level 6
Hi all
I was working on my project for more than month i stuck in a problem that the hardware serial communication doesn't work or it sends me a rubbish values.
may any one help me to convert my code to hex file on his compiler and try it on real pic ?!!
i will be thankful to all of you, i need it as soon as possible.
the attached code needed to be included with default setting for serial connection with 4 Mhz XT
// variables
float vc1,vc2,vc3,beta;
char vc1_txt[15],vc2_txt[15],vc3_txt[15],beta_txt[15],adder_txt[15];
int check;
char uart_rd,adder,lock,add1,add2,receive;
void calculate_beta ()
    beta = ((5 - vc1)* 1000000) / ((5-.7)*3700 ) ;
    FloatToStr(beta,beta_txt);
    Delay_ms(2000);
    UART1_Write_Text(beta_txt);
    Uart1_Write(13);
    Uart1_Write(10);
    Delay_ms (2000);
void Calculate_vc1()
    vc1 = ADC_Read(0);
    vc1 = 0.004887585533*vc1;
    if (vc1 <= 0.2 )
         UART1_Write_Text("S");
    else if (vc1 > 0.2 && vc1 < 4.85 )
         UART1_Write_Text("F");
    else if (vc1 > 4.85)
         UART1_Write_Text("C");
    Uart1_Write(13);
    Uart1_Write(10);
    delay_ms(2000);
void Calculate_vc2()
    vc2 = ADC_Read(1);
    vc2 = 0.004887585533*vc2;
    if (vc2 <= 0.2 )
    else if (vc2 > 0.2 && vc2 < 4.85 )
    else if (vc2 > 4.85)
    Uart1_Write(13);
    Uart1_Write(10);
    delay_ms(2000);
void Calculate_vc3()
    vc3 = ADC_Read(2);
    vc3 = 0.004887585533*vc3;
    if (vc3 <= 0.2 )
    else if (vc3 > 0.2 && vc3 < 4.85 )
    else if (vc3 > 4.85)
    Uart1_Write(13);
    Uart1_Write(10);
    delay_ms(2000);
void lock_check ()
     PORTD = lock & 0x0F ;
     delay_ms (1500) ;
     check = PORTD.F4 ;
     if (check == 1)
         UART1_Write_Text("NO GO");
     else if (check == 0)
         UART1_Write_Text("GO");
    Uart1_Write(13);
    Uart1_Write(10);
    delay_ms(2000);
void full_adder (char a , char b)
   PORTB = ( a & 0x0F )+ ( b & 0xF0 );
   adder = PORTC ;
   adder = adder & 0x1F;
   ByteToStr(adder,adder_txt);
   Uart1_Write_Text(adder_txt);
   Uart1_Write(13);
   Uart1_Write(10);
   delay_ms (2000);
void main() {
     ADRESL = 0x00;
     ADRESH = 0x00;
     TRISA  = 0xFF;
     TRISB  = 0x00;
     TRISC  = 0x9F;
     TRISD  = 0x70;
     CMCON  = 0x07;
     UART1_Init(9600);      // Initialize UART module at 9600 bps
     Delay_ms(100);         // Wait for UART module to stabilize
    while (1) {
            UART1_Write_Text("#");
            while(!UART1_Data_Ready());
            uart_rd = UART1_Read();
            UART1_Write_Text("\r\n");
            Delay_ms(500);
            if (uart_rd == 0x31) {
            calculate_beta();
            Delay_ms(500);}
            else if ( uart_rd == 0x32) {
            Calculate_vc1();
            Delay_ms(500);}
            else if ( uart_rd == 0x33) {
            Calculate_vc2();
            Delay_ms(500);}
            else if ( uart_rd == 0x34) {
            Calculate_vc3();
            Delay_ms(500);}
            else if ( uart_rd == 0x35)
            Uart1_Write(0x61);
            delay_ms(2000);
            lock = UART1_Read();
            lock_check();
            Delay_ms(500);
            else if ( uart_rd == 0x36)
            PORTD.F7 =0 ;
            Uart1_Write(0x61);
            delay_ms(500);
            add1 = UART1_Read();
            Uart1_Write(0x62);
            delay_ms(500);
            add2 = UART1_Read();
            full_adder (add1 , add2);
            Delay_ms(500);
            else if ( uart_rd == 0x37)
            PORTD.F7 =1 ;
            Uart1_Write(0x61);
            delay_ms(500);
            Uart1_Write(0x62);
            delay_ms(500);
            Delay_ms(500);
          else
            break ;
You had the same problem sometime back. Now you have modified your code. right? I think the problem is with your MAX232.
Here are the hex and cof files compiled for 4 MHz.
  • uart.rar
Is it compiled for pic16f877a ?
Has it work on real pic ?!!
