ElGringo
Newbie level 5
- Joined
- Sep 8, 2004
- Messages
- 9
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Houston, TX, USA
- Activity points
- 120
midi to trigger
A while back, using some schematics and info I found on the net, I was able to make me a MIDI controlled switch. When it received a certain midi signal it activated a relay to close a connection on a 1/4" input, thus controlling a remote pedal for my guitar.
Now, I have advance my setup a bit and am faced with a new challenge. I want to make a pedal that sends a MIDI note. I envision the pedal having 4 buttons (UP, PLAY, STOP, DOWN) and a 3 digit LED display to display what note number is currently being sent. I am going to use this to trigger some sound effects on a computer based sampler.
I have come up with a quick schematic (no it isn't 100% correct nor complete), but not 100% knowing what I am doing, I need some guidance on corrections or ways to make this do what I want, but simpler.
I will write a C program for the 16F628 to increment/decrement the current MIDI note number, send the current note number out via the MIDI port when PLAY is pressed, and send a stop note when STOP is pressed, and send the current MIDI note number to the display set (IC1). IC1 will be programmed to display the current note number on the LED Display (1-128).
So, can someone give me some assistance and see what my schematic needs in way of correction to make this work?
Thanks!!
Thanks!!
