Microwind2 - Post Layout Simulation in HSPICE
Rahman.Imran
Newbie level 3
I designed a layout of an Inverter in Microwind2 using 0.12um foundry [CMOS 0.12um - 6 Metal (1.20V, 3.30V)].
I wanted to do a post layout simulation in HSPICE_Z-2007.03. So from Microwind I got the SPICE Netlist and saved it as *.sp file for HSPICE input. I also added the line ".OPTIONS LIST NODE POST" in the netlist. Then I simulated the *.sp file in HSPICE and observed the graphs from Avanwaves. The input and output curve doesn't match with the curve of an inverter. {The Output is greater than the input. I attached the curve here}
I can't figure out the problem. What is wrong with it?
# The layout is correct. Microwind2 simulation shows curves of perfect Inverter.
# From Microwind2 I generated the Netlist for both MOS Models Empirical Level 3 and Advanced BSIM4, none of them works.
Your graph doesn't say which trace is which, but I'd assume
the square blue trace is input since it's ideal looking. Then the
other, presumably output, says to me that you've got no ground
connection and no load, and are just shuttling input charge back
and forth to the output through some device that's attached
to +1.2V and leaking enough to set the DC solution there.
It would be much better if you bothered to include the circuit
you are asking about.
There is Ground Connection in the layout and Vdd+ = 1.2 Volt.
I attached the layout diagram.
Here is the SPICE Netlist I got from Mucrowind2:
And you are right about the curve. The blue line is the input. The input clock is also 1.2 Volt. (Same as Vdd+)
CIRCUIT E:\VLSI Design\Inverter_4Lambda.MSK
* IC Technology: CMOS 0.12µm - 6 Metal
VDD 1 0 DC 1.20
VINPUT 6 0 PULSE(0.00 1.20 0.23N 0.02N 0.02N 0.23N 0.50N)
* List of nodes
* "OUTPUT" corresponds to n°3
* "INPUT" corresponds to n°6
* MOS devices
MN1 0 6 3 0 N1  W= 0.24U L= 0.12U
MP1 1 6 3 1 P1  W= 0.24U L= 0.12U
C2 1 0  0.346fF
C3 3 0  0.218fF
C4 1 0  0.133fF
C6 6 0  0.081fF
* n-MOS BSIM4 :
* low leakage
.MODEL N1 NMOS LEVEL=14 VTO=0.40 U0=0.050 TOX= 3.5E-9 LINT=0.010U
+K1 =0.450 K2=0.100 DVT0=2.300
+DVT1=0.540 LPE0=23.000e-9 ETA0=0.080
+NFACTOR=  1.6 U0=0.050 UA=3.000e-15
+WINT=0.020U LPE0=23.000e-9
+KT1=-0.060 UTE=-1.800 VOFF=0.050
+XJ=0.150U NDEP=170.000e15 PCLM=1.100
+CGSO=100.0p CGDO=100.0p
+CGBO= 60.0p CJSW=240.0p
* p-MOS BSIM4:
* low leakage
.MODEL P1 PMOS LEVEL=14 VTO=-0.45 U0=0.018 TOX= 3.5E-9 LINT=0.010U
+NFACTOR=  1.6 U0=0.018 UA=3.000e-15
+XJ=0.150U NDEP=170.000e15 PCLM=0.700
* Transient analysis
.TEMP 27.0
.TRAN 0.30PS 2.00N
.PROBE
.END
