Tiwana6330
Member level 1
I have a paper cutter knife that runs on 24 volts which is controlled by microcontroller running at 3.3 V. DO-Cut Signal is attached to microcontroller pin. The pin goes high and low but the CN-CUT signal remains at 24 volts. I think there is some problem in resistor values. Can anyone help with what the problem is and how to solve it? Circuit is attached
thanks
thanks
