[SOLVED] Messed With ATMega8 SPIEN setting??
Ok, I'll try to clock this first EXTERNALLY...
BTW what is the DEFAULT ATMega8 setting when it is brand new or never programmed??
The factory setting is internal RC 1MHz , fuses CKSEL3..0 = 0001 (0=programmed , 1=unprogrammed)
The external clock should be connected to XTAL1.
Alex
The factory setting is internal RC 1MHz , fuses CKSEL0..3 = 0001 (0=programmed , 1=unprogrammed)
Alex
Like this??
So I need to set this fuses then add a clock source (which PIN? 9 or 10) to restore my mega8 as good as new?
No, sorry I had it wrong in the previous post (i wrote it inverse CKSEL0..3).
so it should be
CKSEL3 = checked (0)
CKSEL2 = checked (0)
CKSEL1 = checked (0)
CKSEL0 = unchecked (1)
Alex
so it should be
Alex
:p :p
Even expert got mixed up...:D
I think this is the correct setting now...
Yes this setting is correct.
Don't think that I remember the setting from memory, I just check the datasheet for every setting I need, all the settings are listed there so you have to start using it, the picture of the fuse settings in post #3 is from the datasheet and the defaults are also described in the datasheet.
Alex
I was expecting that AVR behaves like PIC...where config/fuses are set during compile..
I never encounter headaches programming PIC..
