Measuring Mutual Coupling
MobiNaz
Full Member level 3
SYDNEY
Hello all,
I am testing two patches resonant at 5.25 and 10.5GHz. They are placed at about 1mm a part such that their feed are next to each other. Their dimensions are different (as evident)
Like in the figure. Now if I want to measure Mutual coupling. For first patch I should measure S12 and for second S21? using network analyser.
Am I thinking in the right direction?
Thanks in advance.
I was looking at this paper
It derives the foirmul afor mutual coupling using dimensions of the patch , Width and Radiation resistance of antenna. In my case Width of both are diffrent .. so what Width I should take, means of which antenna and why? similarly about Radiation resistance.
Secondly, the coupling is for E plane and H plane. Practical measurements would be by placing the antennas in horizontal and vertical plane?
Thanks in advance.
hi, if i use only one port to excite all my array elements,
so is there any issue of mutual coupling? S21 or S12 is the result of using 2 port feeding, but how bout if using only single port?
i also confius with the terms current density, current distribution and surface current, are they most likely the same?
i try to search for info at the internet, but i still cannot get concrete answer. please give ur comment, im greatly appreciate it. thank u
As far as my understanding is, when patches come close / next to each other there will be mutual coupling and the current densities will change , you can theoretically calculate it but am still seeking answer to how to measure them.
i think so too (when patches closer , mutual coupling is exist and significant) BUT many papers i read, all of them speaks on mutual coupling describe in S21..as we know, S21 parameter is from multiport applications....
so i totally out of idea, how to calculate/simulate those mutual couplinga s my array only have 1 input port..what more to say to measure them...( i wish to measure too)
theoretically calculate it? can you suggest me any related links/books/references ?
thanx a lot,
if i found anything useful to be share, ill post them here later =]
Correct. To measure a transmission from one antenna to the other, you need 2 ports.
Very simple. You remove the feed network, and instead connect port 1 directly to one antenna and port 2 directly to the other antenna. That's it. Very simple.
dear volker_muehlhaus:
thank for your kind reply....
so its really need 2 ports then..thx for the info...
about the use of simulation of antenna w/out feeding network...i get what you mean...
but, in my case ...my array have 8 elements with 1 single input port...
so what do u think?
erm, maybe i need to test each of the element alternately??
look forward fo ur reply. TQ
