max length of the ddr2 address signals
ITing
Newbie level 3
Newbie level 3
ddr2 burst
Hi,everyone
I want to write a ddr2 controller in VHDL.
Now, there is a problem in front of me.It is burst length.
In JEDEC standard its value is 4 or 8. when it's 4, it means if you write a data in location0 the location 1,2,3 in the same columne will be assert one by one.The data keep in the location 1,2,3 would be overwrite. How can i keep data safe? The length of data i will write is not fixed, but in byte.
thanks.
ddr2 burst length
Hi.I am writing a SDRAM's controller.
Maybe you can make some special area to store your data respectively,set some counters to store the data's address in turn.
    ITing
burst length ddr2
Use the MASK in the write operation. -> Examine DM input in the JEDEC specification.
    ITing
burst length4 in ddr2
If it is a component, DM is a good choice.But as i know, in DIMM package, DM is usually connected to VSS by mannufacture. Such as HTJ36C512x72G from micron.
:cry:
Added after 11 minutes:
You mean i can store a 4/8xbus_width data first, and then wirte them in one write command.That is a good idea.
But, when the address is not sequential, i think, it maybe can't work well.:cry:
burst length 1 2 4 8
DM inputs doesn't connected to the ground (Vss) in DIMM. I suppose you made such a decision based on the Functional Block Diagram (from HTJ36C512x72G specification)...
I think it will be useful for you to download this doc:
https://download.micron.com/pdf/technotes/ddr2/TN4703.pdf (page 7).
DM arn't independent inputs, but they multiplexed with DQS signals.
I hope it helps.
dd2 burst length
Thanks maksya!
You are right.
"If RDQS is disabled, DQS0-DQS17 bacome DM0-DM8 and DQS9#-DQS17# are not used." This description is found in HTF9C32_64_128x72 datasheet. And in the functional blcok diagram the DM is not connected to Vss also.
But, i am not sure if HTJ36C512x72G is the same. Why its datasheet don't mention it? Is it different?
