[SOLVED] Max analog input for PIC18F452
Stavros84
Junior Member level 2
Hello
I want to give an analog input to PIC18F452 but i am not sure about the maximum value that is accepted.
I want to give from 0-10V. It will be OK?
I read the datasheet and the ADC characteristics (page 287)but i am not sure if 10 volt will work fine.
I know that Vref+ (pin5) has to be greater than the analog input and Vref-(pin4) must be connected to ground.
10 volt isn't ok for micro. You will destroy your microcontroller. Scale it down to 5 volt peak.
good luck
Thank you erio for your help
