volkantr
Junior Member level 2
manchester decoding
Hi everyone
Can anyone share assembly code for decoding manchester coded signals and displaying it with using PIC microcontoller?
The system I try to prove is that
A serial bit stream (manchester coded data) comes into the microcontroller.the protocol of the stream:
firstly 1 byte data comes for timing calibration. after that 1byte (16 bits manchester coded) data comes. After that 2 useless bits(intervals between manchester data transitions) comes. than 1byte (16bits manch. coded,second one) data comes. and again 2 useless bit comes..and it goes like this..
let's say the first 1byte data is the most significant Byte of an adress in the memory and the second one is the LS Byte.
I must decode the data in the micro controller and display immediately on 4-digit 7 segment display.
I've searched for days and all the code I found is about RC5 decoding, actually it can be useful but
The difficulty with this type of decoding is that If we have to do some display multiplexing or some
other time critical work to do along with this decoding ,it creates problems.
also I must say that I'm still a beginner of PIC programming..
Hi everyone
