LT1070 power supply schematic
jmx66
Member level 5
France
Hi all,
I only want to build - if it is possible of course - a small power supply with a LT1070 .
How to replace L1 Coiltronics CTX02-11808-1 ?
Reference of a transformer for say 5 A , and 1.25 to 30 V. Homemade or off the shelf ?
Of course, idem for L2 Coiltronics CTX5-5-FR
Thanks a lot .
jm
  • LT1070-LT1071-Datasheet.pdf
  • LT1070-Design-Manual.pdf
if you give me your spec as follows, ill do you a transformer spec that you can wind yourself on some off the shelf cores.
Vin=?
Vout = 1.25v to 30v?
Iout (max) = 5A ?
Reactions: jmx66
    jmx66
Hi treez,
Thanks a lot for your help, first.
In short, i plan to get:
Transfos 160VA :
12V https://www.reichelt.de/Transformer...=2&ARTICLE=15266&GROUPID=3321&artnr=RKT+16012
15V https://www.reichelt.de/Transformer...=2&ARTICLE=15267&GROUPID=3321&artnr=RKT+16015
Transfos 300 VA :
12V https://www.reichelt.de/Transformer...=2&ARTICLE=40437&GROUPID=3321&artnr=RKT+30012
15V https://www.reichelt.de/Transformer...=2&ARTICLE=40438&GROUPID=3321&artnr=RKT+30015
Bridge B80C25A
https://www.reichelt.de/Rectifiers/...&LA=2&ARTICLE=4668&GROUPID=2998&artnr=B80C25A
Vin : ( 12 x 1,414 ) -1,1 = 16 V
( 15 x 1,414) - 1,1 = 20 V
I= 5 A or 7-8 A for 7-8 A heatsinks and fan mandatory, i think.....
V out 1,25 to 30V
- For L2 Coiltronics CTX5-5-FR what component to buy, in order to withstand 5A or 7 - 8 A , if this current is possible ?
Thanks a lot for your help; that's great.
jm
If you have a 160VA transformer with a 15Vac output, youre right it gives 20V output after the rectifier at the smoothing cap.
Of course, from that point on you can only draw about 0.65*160W because of the poor power factor of rectifier/smoothing cap.
So that’s 104W….which means max current = 104/20 = 5.2amps.
I am not sure what you are using that CTX5-4-R inductor for, but it tells you the current rating in the datasheet.
Reactions: jmx66
    jmx66
Hi treez,
Thanks a lot for your quick reply.
Frankly, i didn't think of a such weak power factor for this bridge!!!!!
I ' m going to google a lot, for CTX5 inductor or similar, in 5A to 8A range.
Thanks a lot.
jm
