[ARM] lpc2148 i2c interfacing with pcf8591 (adc-dac chip)
ravi_karthik
Newbie level 3
Trying to communicate with lpc2148 inbuilt i2c protocol(i2c0) to external adc chip (pcf8591 philips adc-dac chip) to read adc voltage from it.
But proteus simulation with lpc2138 is not responding to the code written.Being a newbie to i2c protocol specifically on LPC2148, can anyone guide me on this.
Slave address = 0x90;
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
#include <LPC21xx.H>
float vol;
unsigned char voltage[7];
//i2c register  configurations
#define STA  0x20
#define SIC  0x08
#define SI   0x08
#define STO  0x10
#define STAC 0x20
#define AA   0x04
// Define LCD PinIO Mask
// RS = P1.16
// EN = P1.17
// D4 = P1.18
// D5 = P1.19
// D6 = P1.20
// D7 = P1.21
#define  LCD_RS     0x00010000                          // P1.16(0000 0000 0000 000x 0000 0000 0000 0000)
#define  LCD_EN     0x00020000                          // P1.17(0000 0000 0000 00x0 0000 0000 0000 0000)
#define  LCD_D4     0x00040000                          // P1.18(0000 0000 0000 0x00 0000 0000 0000 0000)
#define  LCD_D5     0x00080000                          // P1.19(0000 0000 0000 x000 0000 0000 0000 0000)
#define  LCD_D6     0x00100000                          // P1.20(0000 0000 000x 0000 0000 0000 0000 0000)
#define  LCD_D7     0x00200000                          // P1.21(0000 0000 00x0 0000 0000 0000 0000 0000)
#define  LCD_DATA   (LCD_D7|LCD_D6|LCD_D5|LCD_D4)
#define  LCD_IOALL  (LCD_D7|LCD_D6|LCD_D5|LCD_D4|LCD_RS|LCD_EN)
#define  lcd_rs_set() IOSET1 = LCD_RS                   // RS = 1 (Select Instruction)
#define  lcd_rs_clr() IOCLR1 = LCD_RS                   // RS = 0 (Select Data)
#define  lcd_en_set() IOSET1 = LCD_EN                   // EN = 1 (Enable)
#define  lcd_en_clr() IOCLR1 = LCD_EN                   // EN = 0 (Disable)
// xxxx xxx0 0000 0000 0000 0000 0000 0000
#define  lcd_dir_write()  IODIR1 |= 0x003F0000          // LCD Data Bus = Write
//#define  lcd_dir_read()   IODIR1 &= 0xFFC3FFFF            // LCD Data Bus = Read
#define  lcd_clear()          lcd_write_control(0x01)   // Clear Display
#define  lcd_cursor_home()    lcd_write_control(0x02)   // Set Cursor = 0
#define  lcd_display_on()     lcd_write_control(0x0E)   // LCD Display Enable
#define  lcd_display_off()    lcd_write_control(0x08)   // LCD Display Disable
#define  lcd_cursor_blink()   lcd_write_control(0x0F)   // Set Cursor = Blink
#define  lcd_cursor_on()      lcd_write_control(0x0E)   // Enable LCD Cursor
#define  lcd_cursor_off()     lcd_write_control(0x0C)   // Disable LCD Cursor
#define  lcd_cursor_left()    lcd_write_control(0x10)   // Shift Left Cursor
#define  lcd_cursor_right()   lcd_write_control(0x14)   // Shift Right Cursor
#define  lcd_display_sleft()  lcd_write_control(0x18)   // Shift Left Display
#define  lcd_display_sright() lcd_write_control(0x1C)   // Shift Right Display
/* Enable Pulse to LCD */
void enable_lcd(void)                                   // Enable Pulse
  unsigned int i;                                       // Delay Count
  lcd_en_set();                                         // Enable ON
  for (i=0;i<400000;i++);
  lcd_en_clr();                                         // Enable OFF
/* Delay Time Function */
/*    1-4294967296     */
void delay(unsigned long int count1)
  while(count1 > 0) {count1--;}                         // Loop Decrease Counter
/* Strobe 4-Bit Data to LCD */
void lcd_out_data4(unsigned char val)
IOCLR1 = (LCD_DATA);                                    // Reset 4-Bit Pin Data
  IOSET1 = (val<<18);                                   // EN,0,RW,RS:DDDD:0000:0000:0000:0000:0000:0000
/* Write Data 1 Byte to LCD */
void lcd_write_byte(unsigned char val)
  lcd_out_data4((val>>4)&0x0F);                         // Strobe 4-Bit High-Nibble to LCD
  enable_lcd();                                         // Enable Pulse
  lcd_out_data4(val&0x0F);                              // Strobe 4-Bit Low-Nibble to LCD
  delay(100000);
  //while(busy_lcd());                                      // Wait LCD Execute Complete
/* Write Instruction to LCD */
void lcd_write_control(unsigned char val)
  lcd_rs_clr();                                         // RS = 0 = Instruction Select
  lcd_write_byte(val);                                  // Strobe Command Byte
/* Write Data(ASCII) to LCD */
void lcd_write_ascii(unsigned char c)
  lcd_rs_set();                                         // RS = 1 = Data Select
  lcd_write_byte(c);                                    // Strobe 1 Byte to LCD
/* Initial 4-Bit LCD Interface */
void lcd_init()
  unsigned int i;                                       // LCD Initial Delay Count
  PINSEL2  = 0x00000000;                                // GPIO1[31..26] = I/O Function
  lcd_dir_write();                                      // LCD Data Bus = Write
  for (i=0;i<1000;i++);                             // Power-On Delay (15 mS)
  IOCLR1 = (LCD_IOALL);                                 // Reset (RS,RW,EN,4-Bit Data) Pin
  IOSET1 = (LCD_D5|LCD_D4);                             // DDDD:EN,RW,RS,0:0000:0000:0000:0000:0000:0000
  for (i=0;i<100;i++);                              // Delay 4.1mS
  for (i=0;i<100;i++);                                  // delay 100uS
  delay(10000);
  IOSET1 = (LCD_D5);                                    // DDDD:EN,RW,RS,0:0000:0000:0000:0000:0000:0000
  delay(10000);
  lcd_write_control(0x28);                              // Function Set (DL=0 4-Bit,N=1 2 Line,F=0 5X7)
  lcd_write_control(0x0C);                              // Display on/off Control (Entry Display,Cursor off,Cursor not Blink)
  lcd_write_control(0x06);                              // Entry Mode Set (I/D=1 Increment,S=0 Cursor Shift)
  lcd_write_control(0x01);                              // Clear Display  (Clear Display,Set DD RAM Address=0)
  for (i=0;i<100000;i++);                               // Wait Command Ready
/* Set LCD Position Cursor */
void goto_cursor(unsigned char i)
  i |= 0x80;                                            // Set DD-RAM Address Command
  lcd_write_control(i);
/* Print Display Data(ASCII) to LCD */
void lcd_print(unsigned char* str)
  int i;
  for (i=0;i<16 && str[i]!=0;i++)                       // 16 Character Print
     lcd_write_ascii(str[i]);                           // Print Byte to LCD
void InitI2C(void)
     I2CONCLR = 0xFF;
   I2SCLL   = 75;        //speed at 15MHz pclk and i2c bus communication at 100kHz
   I2SCLH   = 75;
     I2CONSET = 0x40;    //Active Master Mode on I2C bus
void SendI2CAddress(unsigned char Addr_S)
    unsigned char r;
        IO0DIR = 0x01;
    I2CONCLR = 0xFF;             // clear I2C - included if User forgot to "StopI2C()"
                                 // else this function would hang.
    I2CONSET = 0x40;             // Active Master Mode on I2C bus
    if((Addr_S & 0x01))          // test if it's reading
       I2CONSET = STA | AA;      // set STA - allow master to acknowlege slave;
    else
       I2CONSET = STA;           // set STA dont allow acknowledges;
    while(I2STAT!=0x08) ;        // Wait for start to be completed
    I2DAT    = Addr_S;           // Charge slave Address
    I2CONCLR = SIC | STAC;       // Clear i2c interrupt bit to send the data
    while( ! ( I2CONSET & SI)) ; // wait till status available
    r=I2STAT;                    // read Status. See standard error codes pdf (link in manual).
    if(!(Addr_S & 0x01))
        {       // if we are doing a write
        if (r != 0x18)
                {             // look for "SLA+W has been transmitted; ACK has been received"
             if ( r==0x20 )          // check for "SLA+W has been transmitted; NOT ACK has been received"
                IO0SET = 0x01; // led at pin0.0 indication no acknowlege - probably no device there. Return a 1 in longjmp
        else
        if (r != 0x40) {             // look for "SLA+R has been transmitted; ACK has been received"
             if ( r==0x48 )          // check for "SLA+R has been transmitted; NOT ACK has been received"
                 IO0SET = 0x01;    // led at pin0.0other error - return status code in longjmp
unsigned char ReadI2C(void)
    unsigned char r;
    I2CONCLR = SIC;                  // clear SIC;
    while( ! (I2CONSET & 0x8));      // wait till status available
    r=I2STAT;                        // check for error
    if (r != 0x50)
        {                  // look for "Data byte has been received; ACK has been returned"
        IO0SET = 0x01;          // led at pin0.0 read fail indication
    return I2DAT;
void WriteI2C(unsigned char Data)
    unsigned char r;
    I2DAT    = Data;                // Charge Data
    I2CONCLR = 0x8;                 // SIC; Clear i2c interrupt bit to send the data
    r=I2STAT;
    if (r != 0x28)
        {                 // look for "Data byte in S1DAT has been transmitted; ACK has been received"
        IO0SET = 0x01;         // led at pin0.0 write fail indication
void StopI2C(void)
    I2CONCLR = SIC;
    I2CONSET = STO;
    while((I2CONSET&STO)) ;         // wait for Stopped bus I2C
float adc_voltage(void)
        // Read the voltage from a PCF8591 A/D device
    unsigned char r;
      PINSEL0  = 0x50;   //  Set pinouts p0.2 and p0.3 as scl0 and sda0 respectively
    InitI2C();
    SendI2CAddress(0x90);    // PCF8591 A/D device address
    SendI2CAddress(0x91);    // Start the read
      SendI2CAddress(0x00);    // Start the read
    ReadI2C();               // dummy read cycle to do the first conversion
    r=ReadI2C();             // read the result
    StopI2C();
    return r;      // return the voltage read
/* Main Program Start Here */
int main(void)
     lcd_init();                                            // Initial LCD
   while(1)                                             // Loop Continue
         vol = adc_voltage()/255*5*10;
     voltage [0] = (unsigned char) vol/10 +0x30;
     voltage [1] = '.';
     voltage [2] = (unsigned char) vol % 10 + 0x30;
     goto_cursor(0x00);                                 // Set Cursor Line-1
     lcd_print(voltage);                        // Display LCD Line-1
         delay(100000);
