AbhayK
Newbie level 1
Hey Guys,
I have been designing a Low Noise Amplifier from 1 to 3 GHz. I am searching for a transistor for my work. Earlier I had used ATF54143 for the design. My goal is to achieve 30K of noise temp throughout the band and its P1dB should be +20dBm atleast.
ATF54143 works fine till 2 GHz (~30K from 1 to 2 GHz). The noise temp in a two stage LNA drastically increases further till 3 GHz to 60K.
FHX40LG looks good device for low noise than ATF54143. But its P1dB at 12 GHz itself is +10dBm. May be it will have still lower at 3GHz.
Does anyone knows about any transistor which is low noise (0.2 to 0.3 dB) AND has a good P1dB (atleast +20dBm)????
Thanks...:grin:
Thanks...:grin:
