logic for transmitting serial data using PIC microcontorller
Here is the circuit I made. I wrote the code in mikroC Compiler. Which Compiler are you using ?
broken link removed
Hello , I am trying to simulate yours same circuit , but my data is not coming out from PIN RB0
Three kinds of clocks are sent which represent 1, 0 or Latch signal. I don't know how you are trying to send the data to HC595. If you mention which Compiler you are using and also show your code and circuit then I can help you.
I run code on same circuit which you provided
It seems you don't want to answer to the questions asked. Did you see the code of the One Wire LCD at the libstock ? It has a send_Byte() function. You have to use it to send data.
I am using C18 complier
C18 projects for testing. Not tested in hardware. I have only tested in Proteus. It displays hardcoded binary values on HC595.
broken link removed
  • One Wire Relay Control rev1.rar
  • One Wire Relay Control.rar
