EEPC
Newbie level 6
Hi all,
I wanted to test the input impedance of a simple common-source transistor with inductive degeneration, and I found that Zin varies considerably with the load impedance (for example simply changing Rload from 100 to 500 ohms). This is not what I expected, because even with a finite Cgd I would not expect Zin to depend on the load that much (since it theoretically depends just on fT and source inductor). Any ideas as to what's causing this? I'm simply driving the gate with an AC current source of unity value and plotting the AC voltage across the source. The test circuit is very simple: single common-source MOSFET with gate and source inductor, and resistive load.
Thanks!
Thanks!
