dhruv_electro
I have tried following circuit to convert my 0-10V DC analog voltage to 0-50Hz (24Vpp) using LM331. But I don’t get the desired output. When I try to build the same circuit on breadboard it gives 24V output on the PIN3 for all the range of 0-10V.
All the capacitors are ceramic disk capacitors.
All the resistors are MFRs.
- Is this IC capable of converting my 0-10V into 0-50Hz(24Vpp)?
- My requirement is NPN output. Is it possible with this IC?
- If both of the answer is Yes, Is there anything I am doing wrong?
