neazoi
Advanced Member level 6
I made this small multi-band transceiver. The TX/RX switch is shown in the TX position.
I notice that there is a TX/RX offset in frequency, which is desired.
However This offset depends on the frequency band the transceiver operates, because the fixed capacitance value has a different effect on each band.
Now I would like to make an adjustable offset for that reason and I first want to investigate where this offset comes from?
Capacitance ot the base to the ground in combination with the 100nf coupling capacitor?
