Jester
Full Member level 6
Linear Voltage regulator with 1% or better accuracy over industrial temperature range
I'm looking for a linear voltage regulator 0.5A output @ 5.0Vdc, accuracy needs to be +/-1% or better over entire industrial temperature range. Input voltage will be between 12 and 24Vdc.
Prefer the simplicity of a 7805 style regulator, with better accuracy. Does such a component exist, and if so part #?
And if not, circuit suggestions for improving the accuracy of a 7805 style regulator?
Thank you
Thank you
