Li-Ion battery USB charger module
muffin_electronics
Newbie level 1
With this battery charger you can use Lithium battery for your projects very simply. All you need is to solder wires from battery and load to the board. Then if you want to charge battery, just plug USB cable in. This board is compatible with almost all modern smartphone chargers. You can run the load and charge the battery at the same time.
You can solder external bi-color status LED which is included. Then you can put it wherever you want to indicate status of the charger.
In attachment you can find a datasheet for this product.
If you are interested, you can buy it on eBay: **broken link removed**
  • docu.pdf
