Meri96
Junior Member level 3
Hello everyone, I am working on SEPIC LED driver for my university project, I designed my LED driver in the simulation program. I used resistance as a load. I run it under PWM control by giving square waves from the signal generator. I get the output values I want in my simulation. Should I change the resistance value and duty value for LED dimming? I looked at the V-i characteristic graph from my LED catalog and entered the resistance value corresponding to the voltage-current values, calculated the new D value for the SEPIC converter according to the V value on V-i graph. When I enter the duty and resistance value in my simulation program, I cannot obtain the desired current and voltage value. I could not be sure whether my technique is wrong. This is my first experience with a Led driver, did I go the wrong way? I will be glad if you help
