if u do it with lpt port ,it will be much easier than serial. if u want to do it with serial port u have to use some extra device i.e microcontroller.
wat u want to do,give complete details.
Hi,ganesh_98422
you can make very simple circuit
You can connect each of pin 2 to 9 to R=220ohm and led then connect all to pin GND(pín8-25) of LPT port!
220Ohm led (GND of LPT port)
it look like: Pin i ---^^^---------|>-----pin GND (i=2 to 9)
and you can test Output port by watching led display!
here is soft to test output Port by watching led displáy
