Layout of a n-well resistor CMOS
biolycans
Member level 2
I designed a n well resistor and in the sofware I am using there is an option to see this layout in 3D. I did this and I saw two things:
1) The N-well material
2) A metal 1 - N-well contact
I don´t understand and I can´t find in any book clearly why in the contact I have around the diffusion N-type a p-type diffusion.
Thank you !
Regards
JC
I recently found that that heavily type N diffusion in the Nwell has the objetive to be an ohmic contact for metal 1, because if I connect the metal 1 directly to the Nwell, then I generate a schottky diode. But I can´t find the reason of the type P around this heavily type N diffusion in the Nwell.
Regards
JC
I can't, either. Is the P diffusion inside the Nwell, or outside? Can you show a picture?
