iDk
12c508a jdm programmer
Hi. i can't program a PIC 16F84A with JDM Programmer on PC with Win98SE OS, PIII 450mhz and ASUS MoBo setup? and also i can't even erased a programmed PIC 16F84A with that PC setup? but i can write and erased a PIC 16F84A on PC with WinME OS & AMD K6-2 300mhz setup (sorry i don't know the MoBo)? i'm using IC-Prog 1.05C and all ic-prog setup were all the same on both PCs. BTW, the error on Win98SE setup is "Verify failed at address 0000h!".... any idea where should be the problem?
thanks
thanks
