ISSUES WITH ALTERA CUSTOM PHY 10GBITS - Alignment
Eligineer
Newbie level 3
I am trying to perform a loopback with an Altera Custom Phy set for 8bit-10bit encoding at the speed of 10gbs with a tx_parallel input of bus of 32bits and a tx_datak of 4bits.
The transceiver is not successfully interpreting the k word it is being sent along with tx_datak being raised.I am watching the transmition and tx_serial is outputing the correct k work successfully. It might have to do with configuration of the ip in mega wizard but i have been unable to detect what is wrong.
Anybody struggle with a similar issue in the past that might lend some insight?
Thanks in advance:)
megawiz_config set for:
sync word: bcbc
order byte: 01 bc 00 00000000
actual photo:
simwave:
