volker@muehlhaus
Advanced Member level 6
For example, if i will put the filter elements, and after that, i will make matching to 50ohm - it will be very bad?
No, that is a good and valid design approach. It also allows to test your device with 50 Ohm test equipment, independent of the load + matching network.
