Internal tri-state bus
ebuddy
Full Member level 3
I have a design, in which there is a hard macro memory IP block. The data bus of the memory is a tri-statable bus. When the memory goes idle, the bus goes high impedance. To prevent the floating net from causing any power leakage issue to other gates, I did a design like the one in the attach diagram.
Basically the NAND gates allow data bus to drive the rest of the logic when and only when EN is high; when EN is low, NAND gate will ignore the voltage level of the floating net, thus effectively block the high impedance from spreading to the rest of the logic.
You guys see any problem with this implementation vs. other methods (weak pull-up/down, bus latch)? Thanks.
ebuddy
It works. Or I'll just enable the memory all the time so that output never goes to high Z.
Yes it will work, but I think giving pull-up will be better. it will reduce noise susceptibility. and it is cost effective too.
are you going to use 16 or 32 NAND gates for 16/32 bit wide bus?
