Intelligent battery charger circuit
how to display an700 on rs232
wat program did u guys use?
does anyone use pic basic pro?
wat software u guys use to draw the circuit?
anyone using pic 16f877 here?
inteligent charger schematics
Does anybody there tried to discharge one single cell?
It's over discharging bellow 0.8 volts.
The improvement from DD to detect one single cell is working properly, but discharge function has problem with one cell.
RenatoBR
atmega8+battery+charger
I have built like i previously post, but i cant charge the battery, anyone have any idea, it sense voltage drop not more than 5 minutes in fast charge mode. i using -delta voltage method to terminate it. can anyone help me with this? I'm using two 2000mAH battery.
100 ah sla smart charger circuit diagram
For wee85 : More details about parts used ?
dc dc converter 1,2v aa battery schematics
This is the circuit i have built, but it terminate so fast in 1st loop of my program.
make a peak detection charger 5v
Your schematic is using pic 16f877 .I have no clue about the software burned into it so I can not help.You could try to contact the author or you could try using my schematic . PIC16F628A is cheapper.
battery charger using irf
Hi all!
I have built the charger and it works great in charging mode. (Tank you Dexter). I have not test the discharge yet, I have to calibrate it more precisely first. I wounder if it would be possible to add an summer how tell you when the charger goes into tricklecharge mode.
Best regards.
intelligent charger project
got anyone used temperature sensor to terminate the charging? can anyone explain to me how to use it if yes?
delta sigma 16f628a picbasic
Hi all.
Now I have test and calibrate my charger. Discharge 1 cell, end at 1113 mV, discharge 4 cell, end at 4420 mV, it`s possible to go lower but I guess it`s better to stay some high, it is always one cell how is worse in a batterypack! I have 803 mV on charger and realterm show 808 mV read 77. The charger take a paus before slow charge and continue with high charge and end in trickle mode in both cases. Well, it works relly good
intelligent battery charger project
is anyone use pic basic pro? i need ppl help me check if my program got any problem or not...
atmega nimh charger
how can i connect battery 1,2,3or 4 conjugated(series) or separately(single one) that all will be charge. pls give connection diagram that according my needs I can charge 1 or 2 or 3 or 4 battery.
Many thanks for guideline.
Can you help, how can stars PIC from beginning?
dexter dude
dexter dude: How long did u put for soft charging state? i had observe that when charging, the voltage is not stable in fast charging state, sometime it increase, and it decrease. Do u have any idea?
Added after 21 minutes:
dexter dude: i use 20% for soft charge, is it sufficient?
i use 1.25A to charge 4 batt NiMH in fast state.
avr battery charger discharger
Hi diginode. You can use batteryholders for R6/AA batterys, they are in different number of cells, from one cell to eight cells, even more I guess. And they are constructed so you always charge the batterys in series, plus to minus and minus to plus and so on.
Fliger
how ot make a simple battery charger for !2v
Fliger
according to this there is no option to charge single battery or 2 or 3 battery. If yes, this will a great bug in circuit. hope it will be recovered.
an700 delta-sigma projects
Diginode,
Read previous messages, all your questions were answered.
The charger works very very wel with 1,2,3 or 4 batteries conected in series.
Renato
atmel irf540
Is this charger suitible for 10cells? I have a 12V NiCd pack with 10 cells and want to charge it.
circuit sla battery charger
Sorry for the delay.
For wee85:
Slow (or soft ) charge is performed for 6 minutes at 50% charge rate.This way some false peak readings are avoided. Yuo could use something like 20-50% for 6-15min .I used only 6 minutes becouse I am charging some 280mA ( at 3C rate ) and I want to be able not to overcharge them .If I would be using 10min at 50% I would be overcharging them.
jonjon : only 1-4 batteries .
intelligent nimh charger schema
dexter dude thank you very much for smart charger project
can i use smart charger to charge 12v 1.3 ah SLA battery ?
best regards
pic microchip chargeur batterie sla
Only NiCd and NiMh ( maximum 4 elements ) are suitable for this particular charger.
nimh delta v charger circuit
Hi. Almost two years ago I developed fully automatic intelligent NiMH/NiCd charger capable of independently charging two AA/AAA 1,2V cells with currents up to 1C. Charger is based on cheap ATtiny26 microcontroller and two switching-mode DC/DC step-down converters. Software uses dT/dt and -ΔV algorithms to cut off charging as well as provides top-off and maintenance charge modes. If you are interested schematics, software and example charging profiles are available here https://www.elektroda.pl/rtvforum/topic862000.html.
