It sort of depends on what you already have. If you have a schematic and PCB and want to add to it, that is easy - simply start a new page and add to it.
If you want to add to the schematic from another schematic, again quite easy - simply cut & paste. Same if you have two PCBs - you can simply cut & paste.
The tricky one is if you have two complete schematics & boards and want to "merge" them.
Maybe you could explain a bit more what you have (PCB/schematic) and what you want to add?
Yes, you can simply cut and paste the board. Open the first board. Ensure all layers are turned on. Group select it. "Cut" it. Then close it and open the other board and paste it. Save AS A NEW NAME just in case it isn't what you want - you don't want to overwrite your originals.
