initialise the counter with desired value verilog/vhdl
mosfets.bjt
Junior Member level 3
i want to design a counter in verilog or vhdl that should start from the desired value, can anyone help?
If your synthesizer allows you to initialize a reg on power on, then you can do that. Best practice is to have a "reset" state where all regs, including your counter, are initialized to desired values.
my synthesizer's name is quartus, for altera
can u \write any eaxmple like what if i want to initialise a 3 bit counter at the value of 3 instead of zero??
Added after 22 minutes:
ok i have found the way
thanks
reset is the best option bcoz it suits all situations......
