Information regarding CAN Microcontroller
popat_panjaru
Full Member level 2
hi to all
right now some of my frds are doing their project regarding to CAN Microcontroller bt i dont have any idea abt this...
can anybody send me some details regarding to CAN Microcontroller...
is it advantageous than PIC OR AVR?
can microcontroller wikipedia
Hi!
CAN is a communication protocol based on the differential bus it is not a different microcontroller.There are lot of microcontrollers by different manufacturers that have built in CAN module e.g Microchip,Atmel, Phillips etc.
Crrently i m using PIC18F4580 in one of my projects.It is a really nice chip with built in CAN module.
If u need code then i can send it to u.
Regards.
canbus pic18f4580
hi
thanks for ur comment
plz send me some more details abt CAN Microcontroller and also that code which u told
it might be more useful to me at the time of learning of CAN
thanks in advance
Popatlal Panjarawala
Re: CAN Microcontroller
if u like to use pic mcu u can use pic18f452 or 18f458 and i attached a cod example of can module writed in ccs c.
  • 00713a_1520.pdf
Dallas have some of the microcontroller that based for ethernet and CAN. Maybe you can do with it. This the datasheet of that microcntroller:
you can built a CAN module wuth your microcontroller but it will take some loading from the controller all the basic information required to know about CAN you can get from www.esacadmy.com and follow the link Online Training
www.microchip.com has the latest PIC chips and design. u can always visit the site to get more information.
where can i get basic introduction about CAN protocol
Added after 1 minutes:
does the introduction to MICROCHIP document provide enough introduciton to CAN
Check this out. It's a basic introduction to CAN
popat_panjaru said:
hi
thanks in advance
CAN per se is not a microcontroller. It's just a communication protocol (designed as an integrated circuit (IC)). It's implemented in a microcontroller as a peripheral with in-build support (by way of SFRs)
Chech this out for more info. https://en.wikipedia.org/wiki/Controller_Area_Network
You may check the links down. Some are very useful!
Added after 59 seconds:
This is another document by microchip
Added after 2 minutes:
This is anothe document by microchip: Controller Area Network (CAN) Basics
