Junus2012
Advanced Member level 5
Hello,
one of the advantages of the closed-loop negative feedback is to improve the amplifier linearity. Therefore, most of the designers I see when they design the op-amp working in closed loop feedback they usually don't care or mention about the op-linearity.
However, I am wondering, and assuming that the negative feedback can not be ideal, hence one at least pay little attention to not completely rely on the feedback performance, for example, fast solution is to design the differential pair transistors with higher overdrive voltage.
Thank you very much
I am looking forward to hear your thaughts
Regards
Thank you very much
Regards
