Hawaslsh
Full Member level 3
- Joined
- Mar 13, 2015
- Messages
- 170
- Helped
- 5
- Reputation
- 10
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Washington DC, USA
- Activity points
- 3,502
Hello,
Had a question about whether or not I need concern myself with impedance matching. The circuit above is pretty standard: filter a down converted IF and amplify for further processing. The IF is ~30 MHz, the mixer (SYM-2500+) i can only assume is matched to 50 Ohms. The LPF are series LC circuits designed for 50 Ohm terminations. Since its a low enough frequency, I was going to use a low noise op-amp in a non-inverting topology, feeding directly to the positive input of the amp.
I realize i just said it was low enough frequency, but should I be concerned about filter and mixer not seeing a 50 ohm termination at the input of the amp? At 30 MHz, is the infinite impedance of the amp even going to matter?
Im going to see what LT-spice says, but just wanted a second opinion or three.
Thanks in advance,
Sami
Thanks in advance,
Sami
