hayder78
Member level 2
I want to use a cypress Psoc microcontroller wich has only 256byte Ram with a multimediacard to log a digitised analog signal into mmc, and as you see it has a small size for a 512byte block to store in its ram before writing to mmc
If the mmc in spi mode can I send a write block command to mmc and send 1 byte then stop the clock signal to the mmc then continue sending clock when the 2nd byte is ready from the ADC.
so if I can cheat the mmc by halting the clock every time WHEN I do not want to send during block write,then every microcontroller with minimum resourcs can use MMC.
Any MMC guru here??
Any MMC guru here??
