IC5141 - -How do I add in LSW ?
AdvaRes
At home
IC5141 LSW
Hi members,
I have just installed IC5141 under Fedora 3. Unfortunately the LSW Editor has only the background layer.
How do I add in LSW (Layer Window) the commonly used
layers (metal_1, poly, pimp, nnwell, etc ...) ?
I think that the problem is related to the tech Files attachement but I dont know the location of that file on my machine.
Is that file given by IC5141 or we have to download it from a IC manufacturer like TSMC ..
Please help.
Thanks in advance.
IC5141 LSW
The technology file is supplied by a foundry.
Re: IC5141 LSW
the layers are not missing but the font for the layer names is missing.
hock
    AdvaRes
IC5141 LSW
Do you have the PDK setup?
IC5141 LSW
At the top of the LSW, the current library name will be displayed. Is it "cdsDefTechLib"? This means you answered "Don't need a technology file" when you created a new library.
Usually a ascii technology file (.tf file) will be provided by foundry. You can use this file to create a new library, or load the ascii technology file to a existing library ( this library should have a techfile, i. e., not connected to another library).
    AdvaRes
