I2C LCD interface with 8051
ISPN
Newbie level 6
Could you please explanin me how to initialize LCD under I2C bus? I used PCF8574T based I2C module to interface LCD. However, I am confusing how to write the command and data in efficient manner.
If you want simple program for I2C ((PCF8574T)) LCD Module (20*4) then here you go
#include <18f4520.h>
#include <stdio.h>
#include <stdlib.h>
#include "lcd20x4.h"
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use delay(clock=4000000)
#use I2C (master, sda = PIN_C4, scl = PIN_C3)
#define LCDADDR        0x70 // default slave address
#define ON            0x08
#define OFF            0x00
#define LCD_SET_BIT(x)    fetch_data(x)
byte LCD_ADDR=0x4e; //I2C slave address for Funduino LCD module
//Transmittion data
void transceiver(unsigned char data)
        i2c_start();
        i2c_write(LCD_ADDR); //the slave addresse
        i2c_write(data);
        i2c_stop();
//Clocking the LCD's enable pin during transmit data
void fetch_data(unsigned char data)
        data=data|0b00000100;//set pin E is a 1
        transceiver(data);
        delay_ms(1);
        data=data-4;//toggle E back to 0
        transceiver(data);
        delay_ms(1);
void lcd_init()
   //Request works on the command by set the RS = 0 R/W = 0 write
        LCD_SET_BIT(0x00);
        LCD_SET_BIT(0x10);
        LCD_SET_BIT(0x00);
        LCD_SET_BIT(0x00);
        LCD_SET_BIT(0x10);
           //First state in 8 bit mode
        LCD_SET_BIT(0x30);
        LCD_SET_BIT(0x30);
           //Then set to 4-bit mode
        LCD_SET_BIT(0x30);
        LCD_SET_BIT(0x20);
           //mode 4 bits, 2 lines, characters 5 x 7 (28 h)
        LCD_SET_BIT(0x20);
        LCD_SET_BIT(0x80);
           //no need cursor on (0Ch)
        LCD_SET_BIT(0x00);
        LCD_SET_BIT(0xC0);
           //the cursor moves to the left (06 h)
        LCD_SET_BIT(0x00);
        LCD_SET_BIT(0x60);
           //clears the display
        LCD_SET_BIT(0x00);
        LCD_SET_BIT(0x10);
void lcd_clear()
    LCD_SET_BIT(0x00);
    LCD_SET_BIT(0x10);
// Need the backlight lid.
void lcd_backlight(byte state)
  LCD_SET_BIT(0x00);
  LCD_SET_BIT(state);
//Display the character on LCD screen.
void display(char in_data)
        char data;
        data=in_data&0xF0;
        data=data+1; //set RS pin to 1
        fetch_data(data);
        data=in_data&0x0F;
        data=data<<4;
        fetch_data(data);
//Make the x/y pointer
void lcd_goto_xy(byte x, byte y)
  byte ptr1, ptr2;
  fetch_data(0x10);
  fetch_data(0x00);
  switch(y)
   case 1:
          ptr1=line_1[x]&0xF0;// stamp the high bit
          ptr2=line_1[x]&0x0F;// stamp the low bit
     break;
   case 2:
           ptr1=line_2[x]&0xF0;
          ptr2=line_2[x]&0x0F;
     break;
   case 3:
          ptr1=line_3[x]&0xF0;
          ptr2=line_3[x]&0x0F;
     break;
   case 4:
           ptr1=line_4[x]&0xF0;
          ptr2=line_4[x]&0x0F;
     break;
   default:
          fetch_data(0x80);
          fetch_data(0x00);
     break;
          ptr2=ptr2<<4;
          fetch_data(ptr1);
          fetch_data(ptr2);
void main()
  char led=0;
  delay_ms(20);
  lcd_init();
        lcd_goto_xy(0,1);
        display("ABCDEFGHIJKLMNOPQRST");
        lcd_goto_xy(0,2);
        display("12345678901234567890");
        lcd_goto_xy(0,3);
        display("AAAAAAAAAAAAAAAAAAAA");
        lcd_goto_xy(6,4);
        display("It's Work.!!!");
        lcd_backlight(ON);
     while(1);
Reactions: ISPN
    ISPN
Thank you so much. I am going to use at89c2051 and assembly. I will try to convert ot to assembly. Thanks a lot
Don't try. This code is useless for you. No one knows what for it was given to you.
2051 doens't have h/w I2c. You have to use s/w method.
You can try use this document to make your own library for I2c. It is more or less clear to understanding.
Not necessarily if you put in software I2C routines for i2c_xxx() functions. Or replace transceiver() respectively.
Reactions: ISPN
    ISPN
Thank you so much. now i am trying.
Thank you so much
This is the code i wrote in assembly. But it does not work. I ma not sure weather i wrote device address correctly. Second i am not sure, that i have to check busy flag in i2C lcd implementation. Please go through my code and give me some suggestions.
  • I2C.txt
