sns22
Member level 2
I am using IAR Workbench with Embedded Artists LPC2468 development board. I am trying to read the status of pressure sensor via I2C. In the code the state of I2CSTAT is not changing and interrupt is not being generated.
I am using I2C0. Can someone point out the mistake?
The main code is below
Thanks in advance!!
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 #include <nxp/iolpc2468.h> #include "i2c.h" #include <intrinsics.h> int main(void) { /*MEMMAP = 0x2;*/ IO0DIR |= 0xF0; i2cReset(); I2C0CONSET = 0x60; while(1) { I2C0CONCLR = 0x40; /* clear flags */ I2C0CONSET = 0x40; /* enable master functions */ } } /***************************************************** * i2c.h: I2C Header file code to test the functionality * ******************************************************/ #ifndef _I2C_H #define _I2C_H #ifndef NULL #define NULL (0) #endif #define FALSE 0 #define TRUE 1 typedef unsigned char tU8; typedef unsigned short tU16; typedef unsigned int tU32; typedef signed char tS8; typedef signed short tS16; typedef signed int tS32; typedef unsigned char tBool; /****************************************************************************** * Defines, macros, and typedefs *****************************************************************************/ /* Fcck = 50Mhz, Fosc = 300Mhz, and USB 48Mhz */ #define PLL_MValue 24 #define PLL_NValue 1 #define CCLKDivValue 5 #define USBCLKDivValue 6 /* System configuration: Fosc, Fcclk, Fcco, Fpclk must be defined */ /* PLL input Crystal frequence range 4KHz~20MHz. */ #define Fosc 12000000 /* System frequence,should be less than 80MHz. */ #define Fcclk 50000000 #define Fcco 300000000 /* APB clock frequence , must be 1/2/4 multiples of ( Fcclk/4 ). */ /* If USB is enabled, the minimum APB must be greater than 16Mhz */ #define Fpclk (Fcclk / 2) /* modes */ #define I2C_MODE_ACK0 0 #define I2C_MODE_ACK1 1 #define I2C_MODE_READ 2 /* return codes */ #define I2C_CODE_OK 1 #define I2C_CODE_DATA 2 #define I2C_CODE_RTR 3 #define I2C_CODE_ERROR -1 #define I2C_CODE_FULL -2 #define I2C_CODE_EMPTY -3 #define I2C_CODE_BUSY -4 #define I2C_SLAVEADR_RCV 0xA1 #define I2C_SLAVEADR_SEND 0xA0 /* I2C Control set register */ #define I2C_CONSET_I2EN 0x40 /* Bit 6: I2EN (I2C interface enable) */ #define I2C_CONSET_I2EN_DISABLED 0x00 /* Disabled */ /* #define I2C_CONSET_I2EN_ENABLED 0x01 Enabled */ #define I2C_CONSET_STA 0x20 /* Bit 5: STA (Start flag) */ #define I2C_CONSET_STA_NO_START 0x00 /* No start */ /* #define I2C_CONSET_STA_START 0x01 Start */ #define I2C_CONSET_STO 0x10 /* Bit 4: STO (Stop flag) */ #define I2C_CONSET_STO_NO_STOP 0x00 /* No stop */ /* #define I2C_CONSET_STO_STOP 0x01 Stop */ #define I2C_CONSET_SI 0x08 /* Bit 3: SI (I2C interrupt flag) */ #define I2C_CONSET_SI_NO_INTERRUPT 0x00 /* No interrupt */ /* #define I2C_CONSET_SI_INTERRUPT 0x01 Interrupt */ #define I2C_CONSET_AA 0x04 /* Bit 2: AA (Assert acknowledge flag) */ #define I2C_CONSET_AA_NO_ACK 0x00 /* Not Acknowledge (Not Acknowledge will be sent when data byte is received) */ /* #define I2C_CONSET_AA_ACK 0x01 Acknowledge (Acknowledge will be sent if certain conditions occur) */ /* I2C status register */ #define I2C_STAT_STATUS 0xF8 /* Bit 7-0: STATUS (Status) */ /* I2C data register */ #define I2C_DATA_DATA 0xFF /* Bit 7-0: DATA (Data) */ /* I2C Slave Address Register */ /* #define I2C_ADDR(replaced by SLAVE)_ADDR 0xfe Bit 7-1: ADDR (Slave mode address) */ #define I2C_SLAVE_ADDR 0x38 /* Bit 7-1: ADDR (Slave mode address) */ #define I2C_SLAVE_GC_GENERAL 0x01 /* Bit 0: GC (General call bit) General call received */ #define I2C_SLAVE_GC_NOT_GENERAL 0x00 /* Not general call */ /* I2C SCL Duty Cycle high register */ #define I2C_SCLH_COUNT 0x007D /* 200kHz Bit 15-0: COUNT (Count for SCL high time period) */ /* I2C SCL Duty Cycle Low Register */ #define I2SCLL_COUNT 0x007D /* 200kHz Bit 15-0: COUNT (Count for SCL low time period) */ /* I2C Control Clear Register */ #define I2C_CONCLR_I2ENC 0x40 /* Bit 6: I2ENC (I2C interface disable) */ #define I2C_CONCLR_I2ENC_NO_EFFECT 0x00 /* No effect */ /* #define I2C_CONCLR_I2ENC_CLEAR 0x01 Clear (I2C Disabled) */ #define I2C_CONCLR_STAC 0x20 /* Bit 5: STAC (Start flag clear) */ #define I2C_CONCLR_STAC_NO_EFFECT 0x00 /* No effect */ /* #define I2C_CONCLR_STAC_CLEAR 0x01 Clear start */ #define I2C_CONCLR_SIC 0x08 /* Bit 3: SIC (I2C interrupt clear) */ #define I2C_CONCLR_SIC_NO_EFFECT 0x00 /* No effect */ /* #define I2C_CONCLR_SIC_CLEAR 0x01 Clear interrupt */ #define I2C_CONCLR_AAC 0x04 /* Bit 2: AAC (Assert acknowledge clear) */ #define I2C_CONCLR_AAC_NO_EFFECT 0x00 /* No effect */ /* #define I2C_CONCLR_AAC_CLEAR 0x01 Clear acknowledge */ void i2cReset(void); __irq void I2C_ISR(void) ; void ISR_8(void); void ISR_18(void); void ISR_28(void); /*tU8 i2cCheckStatus(void); void i2cInit(void); tS8 i2cStart(void); tS8 i2cRepeatStart(void); tS8 i2cStop(void); tS8 i2cPutChar(tU8 data); tS8 i2cGetChar(tU8 mode, tU8* pData); tS8 i2cWrite(tU8 addr, tU8* pData, tU16 len); tS8 i2cRead(tU8 addr, tU8* pBuf, tU16 len); tS8 i2cWriteWithWait(tU8 data);*/ #endif /***************************************************** *presure_tst.c: Demo code to test the functionality ******************************************************/ #include <nxp/iolpc2468.h> #include <intrinsics.h> #include "irq.h" #include "i2c.h" /****************************************************************************** * Defines and typedefs *****************************************************************************/ #define I2C_REG_CONSET 0x40 /* Control Set Register I2C enable */ #define I2C_REG_CONSET_MASK 0x7C /* Used bits */ #define I2C_REG_DATA 0x00 /* Data register */ #define I2C_REG_DATA_MASK 0xFF /* Used bits */ /*I2C in Slave mode */ #define I2C_SLAVE_REG_ADDR 0x00 /* Slave address register */ #define I2C_SLAVE_REG_ADDR_MASK 0xFF /* Used bits */ //#define I2C_REG_SCLH 0x00000040 /* SCL Duty Cycle high register */ /*#define I2C_REG_SCLH 0xF0 SCL Duty Cycle high register */ #define I2C_REG_SCLH 0xC #define I2C_REG_SCLH_MASK 0xFFFF /* Used bits */ //#define I2C_REG_SCLL 0x00000040 /* SCL Duty Cycle low register */ /*#define I2C_REG_SCLL 0x0160 SCL Duty Cycle low register */ #define I2C_REG_SCLL 0xD #define I2C_REG_SCLL_MASK 0xFFFF /* Used bits */ void i2cReset(void) { /*IO0SET |= 0xF0;*/ I2C0ADR = 0x38; PINSEL0 |= 0x00000050; /*rxd0 and txd 0 */ PINSEL0 &= 0xFFFFFF5F; PINSEL1 &= 0xFC3FFFFF; /* sda0 scl0*/ PINSEL1 |= 0x01400000; I2C0CONCLR = 0x6C; /* clear flags */ I2C0CONSET = 0x40; /* enable master functions */ /* reset registers */ I2C0SCLL = ( I2C0SCLL & ~I2C_REG_SCLL_MASK ) | I2C_REG_SCLL; I2C0SCLH = ( I2C0SCLH & ~I2C_REG_SCLH_MASK ) | I2C_REG_SCLH; /*VICIntEnable = 0x00000200; //enable interrupt*/ VICINTENCLEAR=0xffffffff; VICINTSELECT = 0x00; VICINTENABLE |= 0x200; VICVECTPRIORITY9=0x00; VICVECTADDR9 = (unsigned long) &I2C_ISR; } /********************** I2C ISR **************************/ __irq void I2C_ISR(void) { /* unsigned int vector;*/ int temp=0; /* vector=VICADDRESS;*/ temp=I2C0STAT; switch(temp) { case 8: ISR_8(); break; case 24: ISR_18(); break; case 40: ISR_28(); break; default : break; } VICADDRESS=0xFF; } /* I2C states*/ /* Start condition transmitted */ void ISR_8() { /* Port Indicator */ IO0CLR=0x10; /* Slave address + write */ I2C0DAT=0x74; /* Clear SI and Start flag */ I2C0CONCLR=0x28; /* Port Indicator */ IO0SET=0x10; } /* Acknowledgement received from slave for slave address */ void ISR_18() { /* Port Indicator */ IO0CLR=0x20; /* Data to be transmitted */ I2C0DAT=0x55; /* clear SI */ I2C0CONCLR=0x8; /* Port Indicator */ IO0SET=0x20; } /* Acknowledgement received from slave for byte transmitted from master. Stop condition is transmitted in this state signaling the end of transmission */ void ISR_28() { /* Port Indicator */ IO0CLR=0x80; /* Transmit stop condition */ I2C0CONSET=0x10; /* clear SI */ I2C0CONCLR=0x8; /* Port Indicator */ IO0SET=0x80; }
