See this discussion:tamphuong said:* To change metal layer by press a assign button.
It's all available in the link mentioned above. If you know how to use skill, you should be able to extract the code you need from the link's answers.tamphuong said:I select layer(s) metal 1 path then press button "2". Selected layer(s) metal1 will change to metal 2.
thank in advance.
