Hi AkanimoHi,
It's not very clear what you are showing. Are you showing them as Pins 1, 2 and 3 from left to right?
--- Updated ---
It seems like you're missing some high-side drivers.
the best way to get the pinouts is from the manufacturer's data sheet
watch for top view or bottom view
why are you using four different devices?
usual is four identical switching transistors,
or two identical on high side and two identical on low side
Hi Broi watched the video
it shows a finished device that appears to be operating
since it isn't clear what its supposed to do, it isn't clear that it works
it provides no information on the circuit or the components
the guy who posted the video gives a website and an email address for questions and help
maybe you should try that
Many thanks for the response bro. You mean to say R12 should go to base ? In the base there is already R13 is connected with led.The MOSFETs have source and drain flipped, the PNP transistor has all pins wrong. Supply voltage should go to emitter terminal, R12 to base.
ExactlyThe circuit is supposed to use very powerful magnetic pulses to clean your blood of viruses and pathogens better than drinking Lysol!
The author says he is a "spiritualist" which might be a Wanna-Be Quack doctor.
Yes, I said all pins are wrong. R13 connects t collector pin.In the base there is already R13 is connected with led.
