[PIC] I have two questions about the controller PIC16F886 related to ADC
dor8
Junior Member level 1
hi,
1.
I want to know what until which voltage the ADC can measure?
my circuit works between voltages 26V to 52V and I want to know if the ADC knows measure such voltages without making a voltage divider?
* Data sheet does not say obvious - Write high voltage.
2.
Can I please get some examples of C programs that explain to me how I work with the registers of the ADC?
* I work with COMPILER of HIGH-TECH
3.
Does anyone know if there is a component of the multi Sim?
**I have not found a component of controller
Thank you and good day
Thank you ..
Can you please bring me examples of programs (I'm basically doing Converter).
I just want to understand how to use the registers of the ADC?
**I'm using a controller pic 16f886 and HIGH-TECH COMPILER
This is how you initialize ADC process: (you call it in the main function)
ADCINIT
    MOVLW 0X0E
    MOVWF ADCON1
    MOVLW b'00000001'
    MOVWF ADCON0
    RETURN
This is the process itself:
CONAD
    BSF ADCON0,1
    CALL REPEAT
    MOVFF ADRESH,PORTD
REPEAT  BTFSC ADCON0,1
           GOTO REPEAT
           RETURN
