hyperterminal problem
elionidas
Newbie level 5
I use EDK 11.1 and To create powerpc processor, I used BSB wizard in XPS and for C code I used the "Add software application project".
The problem is that after doing all steps for programming FPGA (ML507) nothing appear in the HyperTerminal. But when I build the project" TestAppl_MEMORY_ppc440_0 the HT work well !!!!!!!!!
I make my Baud at 9600,stop-bits, parity in XPS for UARTLITE.
Plz any suggestions for my problem
put print statements in c code test it in hyper terminal may be its looping in your program...
OR
debug using SDK
BEGIN xps_uartlite
PARAMETER INSTANCE = RS232
PARAMETER HW_VER = 1.01.a
PARAMETER C_BAUDRATE = 57600
PARAMETER C_DATA_BITS = 8
PARAMETER C_ODD_PARITY = 0
PARAMETER C_USE_PARITY = 0
# 125000000
PARAMETER C_SPLB_CLK_FREQ_HZ = 100000000
PARAMETER C_BASEADDR = 0x84000000
PARAMETER C_HIGHADDR = 0x8400ffff
BUS_INTERFACE SPLB = plb_v46_0
PORT RX = fpga_0_RS232_RX
PORT TX = fpga_0_RS232_TX
END
im use ZOC/ 8N1
