[SOLVED] HSPICE 2013 SP2 28T Full Adder Simulation Problem
manili
Member level 1
Hi all,
I'm trying to simulate a 28 Transistor CMOS Full Adder using HSPICE 2013 SP2. Here is the picture of what I'm trying to implement.
This is my HSPICE code:
CMOS Full Adder
.include		'../32nm_LP.pm'
.temp			25
.param 			tech_lngth=32n
.param			vmax=0.9
.param			wnmos=64n
.param			wpmos=160n
.SUBCKT		FA		A		B		C		COUT	SUM			VSS		VDD
MPA1		VDD		A		U1		VDD		PMOS	W=wpmos		L=tech_lngth
MPB1		VDD		B		U1		VDD		PMOS	W=wpmos		L=tech_lngth
MPA2		U1		A		U2		VDD		PMOS	W=wpmos		L=tech_lngth
MPB2		U2		B		OUT1	VDD		PMOS	W=wpmos		L=tech_lngth
MPC1		U1		C		OUT1	VDD		PMOS	W=wpmos		L=tech_lngth
MNC1		OUT1	C		D1		VSS		NMOS	W=wnmos		L=tech_lngth
MNA1		D1		A		VSS		VSS		NMOS	W=wnmos		L=tech_lngth
MNB1		D1		B		VSS		VSS		NMOS	W=wnmos		L=tech_lngth
MNA2		OUT1	A		D2		VSS		NMOS	W=wnmos		L=tech_lngth
MNB2		D2		B		VSS		VSS		NMOS	W=wnmos		L=tech_lngth
MPI1		VDD		OUT1	COUT	VDD		PMOS	W=wpmos		L=tech_lngth
MNI1		COUT	OUT1	VSS		VSS		NMOS	W=wnmos		L=tech_lngth
MPA3		VDD		A		U3		VDD		PMOS	W=wpmos		L=tech_lngth
MPB3		VDD		B		U3		VDD		PMOS	W=wpmos		L=tech_lngth
MPC3		VDD		C		U3		VDD		PMOS	W=wpmos		L=tech_lngth
MPA4		U3		A		U4		VDD		PMOS	W=wpmos		L=tech_lngth
MPB4		U4		B		U5		VDD		PMOS	W=wpmos		L=tech_lngth
MPC4		U5		C		OUT2	VDD		PMOS	W=wpmos		L=tech_lngth
MNA3		D3		A		VSS		VSS		NMOS	W=wnmos		L=tech_lngth
MNB3		D3		B		VSS		VSS		NMOS	W=wnmos		L=tech_lngth
MNC3		D3		C		VSS		VSS		NMOS	W=wnmos		L=tech_lngth
MNA4		OUT2	A		D4		VDD		NMOS	W=wnmos		L=tech_lngth
MNB4		D4		B		D5		VDD		NMOS	W=wnmos		L=tech_lngth
MNC4		D5		C		VSS		VDD		NMOS	W=wnmos		L=tech_lngth
MPI2		U3		OUT1	OUT2	VDD		PMOS	W=wpmos		L=tech_lngth
MNI2		OUT2	OUT1	D3		VSS		NMOS	W=wnmos		L=tech_lngth
MPI3		VDD		OUT2	SUM		VDD		PMOS	W=wpmos		L=tech_lngth
MNI3		SUM		OUT2	VSS		VSS		NMOS	W=wnmos		L=tech_lngth
.ENDS		FA
X1			A		B		C		COUT1	SUM1	G_VSS		G_VDD		FA
X2			A		SUM1	COUT1	COUT2	SUM2	G_VSS		G_VDD		FA
vSupply		G_VDD	0		vmax
vGround		G_VSS	0		0
vA			A		G_VSS	0		PULSE	0		vmax		0.5N 		0.01N 		0.01N		10N			20N
vB			B		G_VSS	0		PULSE	0		vmax		0.5N 		0.01N 		0.01N		20N			40N
vC			C		G_VSS	0		PULSE	0		vmax		0.5N 		0.01N	 	0.01N		40N			80N
.TRAN		1P		80.5N
.END
After simulation, I try to show the result using CScope software. Everything works fine except result of the SUM when A = B = C = 1.
I'll add a pic of simulation in the attachments.
Any ideas?
A schematic diagram is easier to analyze than the netlist.
Don't you have this?
@andre_teprom,
Thanks a lot for the reply. Unfortunately I'm implementing the circuit fully in HSPICE (for learning purposes).
I don't know if there is a tool to convert HSPICE to schematic or vice versa?
We usually implement a circuit in a top-down approach, and so I suppose you have at least one readable scribble in the paper of that you have implemented above, preferably assigning the nodes of the netlist..
I added the schematic in the attachment.
Thanks.
Copy and paste error?
MNB4	D4	B	D5	[COLOR="#FF0000"]VDD[/COLOR]	NMOS	W=wnmos	L=tech_lngth
MNC4	D5	C	VSS	[COLOR="#FF0000"]VDD[/COLOR]	NMOS	W=wnmos	L=tech_lngth
Reactions: manili
    manili
That was awesome!!! You just solved my problem. Thanks a lot :))
Do you have any ideas why I'm getting negative output (about micro volts) sometimes? Is it OK?
Maybe gate crosstalk, or transient solution inaccuracy. Surely not a problem.
Reactions: manili
    manili
