How to use codes generated in custom character generator of Mikrobasic Pro?
newbie111
Member level 2
h.k
hi,
Any folks here using mikrobasicpro
it has a built- in custom character generator
I am wondering if anyone can show me some examples codes for any pics
how to use the generated codes there
Thanks
mikrobasic pro
I found out how to do it.
Say this is the custom sub that is generated:
const character as byte[8] = (0,10,0,21,17,14,0,0)
sub procedure CustomChar(dim pos_row as byte, dim pos_char as byte)
  dim i as byte
    LCD_Cmd(64)
    for i = 0 to 7
      LCD_Chr_Cp(character[i])
    next i
    LCD_Cmd(_LCD_RETURN_HOME)
    LCD_Chr(pos_row, pos_char, 0)
end sub
Then in your main code call this sub routine just like you'd call LCD_Out.
e.g.
program LCD_Cust
dim LCD_RS as sbit at RB4_bit
    LCD_EN as sbit at RB5_bit
    LCD_D4 as sbit at RB0_bit
    LCD_D5 as sbit at RB1_bit
    LCD_D6 as sbit at RB2_bit
    LCD_D7 as sbit at RB3_bit
    LCD_RS_Direction as sbit at TRISB4_bit
    LCD_EN_Direction as sbit at TRISB5_bit
    LCD_D4_Direction as sbit at TRISB0_bit
    LCD_D5_Direction as sbit at TRISB1_bit
    LCD_D6_Direction as sbit at TRISB2_bit
    LCD_D7_Direction as sbit at TRISB3_bit
  dim i as byte
    LCD_Cmd(64)
    for i = 0 to 7
    next i
end sub
main:
     LCD_Init()
     LCD_Cmd(_LCD_CURSOR_OFF)
     LCD_Cmd(_LCD_CLEAR)
     CustomChar(1, 6) 'Print custom character on row 1, column 6
     while true
     wend
end.
Hope it helped.
Tahmid.
    newbie111
Re: mikrobasic pro
WELL DONE!!!!!!!!!!!!!!!
Pal,
I do not know what to say you are smart, helpful and all that.
It worked finally!
^______________^
I hereby want to thank you for asking me to download mikrobasic
I am now using it with joy!
Best regards,
Simon
