ysz
- Joined
- Aug 14, 2004
- Messages
- 44
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- fujian china
- Activity points
- 442
initial conditions crystal oscillator spice
.OPTIONS RMAX and FS
Breakpoint locations for a PWL source
Breakpoint locations for a PULSE source
Smallest period for a SIN source
Smallest delay for a transmission line component
Smallest ideal delay for a transmission line component
TSTEP value in a .TRAN analysis***********
Number of points in an FFT analysis
the tsetp in .tran sentance will change the delmax, the delmax will change the accurcy of the simulation.
so I through it is useful.
Factors that determine the computed DELMAX value are:Hughes said:r23718 said:changing 1u to 100n in .tran 1u 200000u
will not help - it is "initial" sep size. Simulator will then change step size to anything.
Maybe you are right. But I have ever heard someone encountered the same problem -- the output swing is too small. He finally solved the problem by changing the transient step size to 0.1ns.
I don't know why.
