How to show adc value in seven segment display using mikroc and proteus
khatus
Member level 3
Hello, Guys, I wanted to show adc value in 7 segments dynamic display. I am using ADC channel 1 for this purpose. But while simulating in the proteus it shows the following error.Also, some random digits show in the display. I can't figure out the error. Please update my code if possible .........
moderator action: removed link to external file servers
Here is my full code
* 7-Segment common anode display for showing ADC value read from channe-1 of analog pin
* Programmer: SRikrishna Jana
* Target PIC: PIC16F877
* Frequency 8 Mhz
* Date: 5th august 2021
* Display on 3-digit 7 SEGMENT display
unsigned char SEGMENT=0;
sbit C1 at RD0_bit; // C1--->C4 are for turnig on the common anode display
sbit C2 at RD1_bit; // If C1=1 display is on if C1=0  display is off
sbit C3 at RD2_bit; //Same rule follows C2,C3,C4
sbit C4 at RD3_bit;
//unsigned int value;
const unsigned char DriveSegment[10] =  { 192, 249, 164, 176, 153, 146, 130, 248, 128, 152 }; //Digit code for 0 to 9
void UpdateDisplay(unsigned int value)
     unsigned int SendVal = value;
     unsigned char Digit;
        SEGMENT++;
        if (SEGMENT > 4)
         SEGMENT = 1;
        C1 = 0; C2 = 0; C3 = 0,C4 =0; //Initially Displays are off
switch (SEGMENT){
               case 1:
                    Digit = (unsigned char) (SendVal / 1000); // Suppose ADC value= 1023 This gives you 1.
                    C1=1; //turn on the display
                    delay_ms(10);
                    C1=0; //turn off the display
                    break;
               case 2:
                    Digit = (unsigned char) ((SendVal / 100) % 10);//This gives you 0.
                    C2=1; //turn on the display
                    delay_ms(10);
                    C2=0; //turn off the display
                    break;
               case 3:
                    Digit = (unsigned char) ((SendVal / 10) % 100);//This gives you 2.
                    C3=1; //turn on the display
                    delay_ms(10);
                    C3=0;  //turn off the display
                    break;
               case 4:
                    Digit = (unsigned char) (SendVal % 10);//This gives you 3.
                    C4=1; //turn on the display
                    delay_ms(10);
                    C4=0;//turn off the display
                    break;
        SendVal = DriveSegment[Digit] & 0xFF;
        PORTB = SendVal;
unsigned int  ADC_reading(void )
    unsigned int value_adc;
    ADC_Init();
    value_adc = ADC_Read(1);
    delay_us(10);
    return(value_adc);
void main()
unsigned int value;// variable for storing adc value
TRISB=0x00;// B0 to B6 declared as a output
PORTB = 0x00;//Initially PORTB is OFF
TRISD=0x00; // D0 to D3 declared as a output
PORTD = 0x00;// Initially PORTD is OFF
TRISA.F1 =1;
ADCON0.F5=0; //*For channel 1
ADCON0.F4=0; //*For channel 1
ADCON0.F3=1; //*For channel 1
while(1)
value = ADC_reading(void) ;//call the ADC_reading function for reading analog channel 1
UpdateDisplay(value);// pass the valor to UpdateDisplay function for showing to seven segment display
This should be your complete homework assignment:
C:
* File:   main.c
* Author: dan1138
* Target: PIC16F877
* Compiler: XC8 v2.32
* IDE: MPLABX v5.50
* Created on August 7, 2021, 11:06 PM
*                         PIC16F877
*                 +----------:_:----------+
*       VPP ->  1 : MCLR/VPP      PGD/RB7 : 40 <> PGD/seg_dp
*  Volts IN ->  2 : RA0/AN0       PGC/RB6 : 39 <> PGC/seg_g
*           <>  3 : RA1               RB5 : 38 <>    /seg_f
*           <>  4 : RA2               RB4 : 37 <>    /seg_e
*           <>  5 : RA3           PGM/RB3 : 36 <>    /seg_d
*           <>  6 : RA4               RB2 : 35 <>    /seg_c
*           <>  7 : RA5               RB1 : 34 <>    /seg_b
*           <>  8 : RE0               RB0 : 33 <>    /seg_a
*           <>  9 : RE1               VDD : 32 <- 5v0
*           <> 10 : RE2               VSS : 31 <- GND
*       5v0 -> 11 : VDD               RD7 : 30 <>
*       GND -> 12 : VSS               RD6 : 29 <>
*      8MHz -> 13 : OSC1              RD5 : 28 <>
* 1    8MHz <- 14 : OSC2              RD4 : 27 <>
*           <> 15 : RC0/SOSCO   RX/DT/RC7 : 26 <>
*           <> 16 : RC1/SOSCI   TX/CK/RC6 : 25 <>
*           <> 17 : RC2/CCP1          RC5 : 24 <>
*           <> 18 : RC3/SCL       SDA/RC4 : 23 <>
*   digit_1 <> 19 : RD0               RD3 : 22 <> digit_4
*   digit_2 <> 20 : RD1               RD2 : 21 <> digit_3
*                          DIP-40
* Description:
*  Drive 4-digit LED 7-segment display with a
*  three decimal value from ADC reading the
*  voltage at AN0.
*  The display range is from 000 to 500 in
*  digits 1 to 3, digit 1 is the hundreds,
*  digit 2 is the tens and digit 3 is ones.
#pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config CP = OFF         // FLASH Program Memory Code Protection bits (Code protection off)
#pragma config BOREN = OFF      // Brown-out Reset Enable bit (BOR disabled)
#pragma config LVP = OFF        // Low Voltage In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF        // Data EE Memory Code Protection (Code Protection off)
#pragma config WRT = ON         // FLASH Program Memory Write Enable (Unprotected program memory may be written to by EECON control)
#define _XTAL_FREQ (8000000UL)
#include <xc.h>
/* LED is common anode so zero is segment on */
const char LEDDigit[] =
  /* gfedcba         _   */
  0b11000000,   /*  | |  */
                /*  |_|  */
  0b11111001,   /*    |  */
                /*   _   */
  0b10100100,   /*   _|  */
                /*  |_   */
                /*   _   */
  0b10110000,   /*   _|  */
                /*   _|  */
  0b10011001,   /*  |_|  */
                /*   _   */
  0b10010010,   /*  |_   */
                /*   _|  */
                /*   _   */
  0b10000010,   /*  |_   */
                /*  |_|  */
                /*   _   */
  0b11111000,   /*    |  */
                /*   _   */
  0b10000000,   /*  |_|  */
                /*  |_|  */
                /*   _   */
  0b10011000,   /*  |_|  */
  0b11111111    /* blank */
* Global RAM
unsigned char DigitSegments[4];
unsigned char DigitOn;
* Initialize this PIC
void PIC_Init(void)
    /* disable all interrupt sources */
    INTCON = 0x00;
    PIE1 = 0x00;
    PIE2 = 0x00;
    ADCON0 = 0xC1;          /* turn on ADC module */
                            /* TAD = ADFRC */
                            /* Select AN0 as input */
    ADCON1 = 0x8E;          /* set PORTA AN0 for analog input all others for digital I/O */
                            /* ADC results are right justified */
    TRISB = 0x00;
    TRISD = 0xF0;
    PORTB = 0xFF;
    PORTD = 0xF0;
    DigitOn = 0;
    DigitSegments[0] = LEDDigit[10];
    DigitSegments[1] = LEDDigit[10];
    DigitSegments[2] = LEDDigit[10];
    DigitSegments[3] = LEDDigit[10];
* Main application
#define ADC_VREF_cV (500) /* VREF in centivolts (1/100ths of a volt) */
unsigned long ADC_Raw;
void main(void)
    PIC_Init();
     * Application process loop
    for(;;)
        /* Turn on next LED digit */
        PORTB = 0xFF;      /* Turn off all segments */
        PORTD &= 0xF0;
        PORTD |= 0x0F & DigitOn;
        if(DigitOn & 1) PORTB = DigitSegments[0];
        if(DigitOn & 2) PORTB = DigitSegments[1];
        if(DigitOn & 4) PORTB = DigitSegments[2];
        if(DigitOn & 8) PORTB = DigitSegments[3];
        DigitOn <<= 1;
        /* Check of all four LED digits have been refreshed */
        if(!(DigitOn & 0x0F))
            DigitOn = 1;
            /* Read ADC */
            ADCON0bits.GO_nDONE = 1;
            while(ADCON0bits.GO_nDONE){}
            ADC_Raw = ((unsigned short)(ADRESH)<<8) | ADRESL;
            /* Convert to decimal value in range from 000 to 500 */
            ADC_Raw *= ADC_VREF_cV;
            ADC_Raw += (1<<9);
            ADC_Raw >>= 10;
            /* Convert ADC decimal value to 7-segments */
            DigitSegments[3] = LEDDigit[ADC_Raw % 10];
            ADC_Raw /= 10;
            DigitSegments[2] = LEDDigit[ADC_Raw % 10];
            ADC_Raw /= 10;
            DigitSegments[1] = LEDDigit[ADC_Raw % 10];
        /* Make process loop take at least one millisecond */
        __delay_ms(1);
Reactions: khatus
    khatus
