How to set code two 7 Segments in a single port
Nik Zhafran
Junior Member level 1
Shinjuku-ku, Tokyo, Japan, Japan
at89c51 in asm program using keil ...
How to make code with using 1 port and 2 7 segment ?
should i make like this ?
HTML:
        data_one    equ    P2.4,2.5,2.6,2.7
        data_ten    equ    P2.0,2.1,2.2,2.3
try yourself with this clue. use 'swap' instruction and accumulator
It is like down ?
HTML:
			  Org    00H
        data_a   equ    P2
	IPIN		EQU	P1.0
	DPIN		EQU	P1.1
        Mynumber    Equ    30H
HTML:
; Conversi hex to perpuluhan
BCD:    Mov     A,Mynumber
        MOV B,#10
        DIV AB
        SWAP A
        ORL A,B
        MOV P2,A
        mov dptr,#seg_conv
	MOVC A,@A+DPTR    ; MOVE DATA @A+DPTR IN A
        mov    data_a, A
Ret
you dont required these lines
erm thank you it work perfect but how to make it 01,02
because when i run it start from left 10,20,30,40....
This code i put in data aray seven segment
HTML:
; Data aray seven segment
Seg_conv:
	DB    00H    ; 0
        DB    01H    ; 1
        DB    02H    ; 2
        DB    03H    ; 3
        DB    04H    ; 4
        DB    05H    ; 5
        DB    06H    ; 6
        DB    07H    ; 7
        DB    08H    ; 8
        DB    09H    ; 9
        END
either change hardware or mov the contents of B first then A. try, just extra 2 more extra code
Thank it really work ..i change 10 to 01 at MOV B,#01 but if that number reach to 9 when press it display not ten but ***** number like 2 or 3 time press and go number 10 and onther like 19 and press again it out number that don't know like three time press and out 20 ....
HTML:
			  Org    00H
        data_a   equ    P2
	IPIN		EQU	P1.0
	DPIN		EQU	P1.1
        Mynumber    Equ    30H
main_prog:
	CALL INIT
AGAIN:
AG2:	JB IPIN,AG1
	CALL DELAY1	;debounce
	JB IPIN,AG1
	JNB IPIN,$	;wait till switch release
	INC MYNUMBER
	mov a,mynumber
	cjne a,#100,pq1
	mov mynumber,#01
pq1:
	call bcd	;diaplay data
AG1:	JB DPIN,AG2
	CALL DELAY1
	JB DPIN,AG2
	JNB DPIN,$
	clr mynumber
	mov a,#0C0H
	cjne a,#0C0H,pq2
	mov mynumber,#00
pq2:
	call bcd
	JMP AGAIN
INIT:
	MOV    data_a,#00H
        MOV    data_a,#00H
        mov    Mynumber,#0
        mov    p1,#255        ;set port 1 as input BY . IT SHOULD BE 1
RET
DELAY1:	MOV R4,#255
	DJNZ R4,$
RET
BCD:    Mov     A,Mynumber
        MOV B,#01
        DIV AB
        SWAP A
        ORL A,B
        MOV P2,A
Ret
; Tunda
delay:  MOV    R5,#0ffh
        MOV    R6,#0ffH
        MOV    R7,#2
delay_loop:    DJNZ    R5,delay_loop
        DJNZ    R6,delay_loop
        DJNZ    R7,delay_loop
        RET
Seg_conv:
	DB    00H    ; 0
        DB    01H    ; 1
        DB    02H    ; 2
        DB    03H    ; 3
        DB    04H    ; 4
        DB    05H    ; 5
        DB    06H    ; 6
        DB    07H    ; 7
        DB    08H    ; 8
        DB    09H    ; 9
        END
BCD: Mov A,Mynumber
MOV B,#01
DIV AB
SWAP A
ORL A,B
MOV P2,A
Ret
BCD: Mov A,Mynumber
MOV B,#10
DIV AB
MOV R3,A
MOV A,B
SWAP A
ADD A,R3 ; check this command is right or use suitable one
MOV P2,A
Ret
mikroC PRO 8051 code attached. See the .lst file for asm code generated by compiler.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
unsigned char counter = 0, bcd = 0, bcdU = 0, bcdL = 0;
char Dec2Bcd(unsigned char dec) {
  return (((dec / 10) << 4) | (dec % 10));
void main() {
    P0 = 0x00;
    P1 = 0x00;
    P2 = 0x03;
    P3 = 0x00;
    while(1) {
          if(!P2_0_bit) {
             Delay_ms(30);
             while(!P2_0_bit);
             if(counter < 99)++counter;
          if(!P2_1_bit) {
             Delay_ms(30);
             while(!P2_1_bit);
             if(counter > 0)--counter;
          bcd = Dec2Bcd(counter);
          bcdU = (bcd & 0x0F) << 4;
          bcdL = bcd >> 4;
          P3 = bcdU | bcdL;
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
_Dec2Bcd:
;dec2bcd2ssd.c,3 ::                 char Dec2Bcd(unsigned char dec) {
;dec2bcd2ssd.c,4 ::                 return (((dec / 10) << 4) | (dec % 10));
        MOV B+0, #10
        MOV A, FARG_Dec2Bcd_dec+0
        DIV AB
        MOV R2, A
        MOV R0, #4
        MOV A, R2
        INC R0
        SJMP L__Dec2Bcd10
L__Dec2Bcd11:
        CLR C
        RLC A
L__Dec2Bcd10:
        DJNZ R0, L__Dec2Bcd11
        MOV R1, A
        MOV B+0, #10
        DIV AB
        MOV A, B+0
        MOV R0, A
        MOV A, R1
        ORL 0, A
;dec2bcd2ssd.c,5 ::                 }
        RET
; end of _Dec2Bcd
_main:
        MOV SP+0, #128
;dec2bcd2ssd.c,7 ::                 void main() {
;dec2bcd2ssd.c,9 ::                 P0 = 0x00;
        MOV P0+0, #0
;dec2bcd2ssd.c,10 ::                 P1 = 0x00;
        MOV P1+0, #0
;dec2bcd2ssd.c,11 ::                 P2 = 0x03;
        MOV P2+0, #3
;dec2bcd2ssd.c,12 ::                 P3 = 0x00;
        MOV P3+0, #0
;dec2bcd2ssd.c,14 ::                 while(1) {
L_main0:
;dec2bcd2ssd.c,16 ::                 if(!P2_0_bit) {
        JB P2_0_bit+0, L_main2
        NOP
;dec2bcd2ssd.c,17 ::                 Delay_ms(30);
        MOV R6, 54
        MOV R7, 201
        DJNZ R7,
        DJNZ R6,
;dec2bcd2ssd.c,18 ::                 while(!P2_0_bit);
L_main3:
        JB P2_0_bit+0, L_main4
        NOP
        SJMP L_main3
L_main4:
;dec2bcd2ssd.c,19 ::                 if(counter < 99)++counter;
        CLR C
        MOV A, _counter+0
        SUBB A, #99
        JNC L_main5
        INC _counter+0
L_main5:
;dec2bcd2ssd.c,20 ::                 }
L_main2:
;dec2bcd2ssd.c,22 ::                 if(!P2_1_bit) {
        JB P2_1_bit+0, L_main6
        NOP
;dec2bcd2ssd.c,23 ::                 Delay_ms(30);
        MOV R6, 54
        MOV R7, 201
        DJNZ R7,
        DJNZ R6,
;dec2bcd2ssd.c,24 ::                 while(!P2_1_bit);
L_main7:
        JB P2_1_bit+0, L_main8
        NOP
        SJMP L_main7
L_main8:
;dec2bcd2ssd.c,25 ::                 if(counter > 0)--counter;
        SETB C
        MOV A, _counter+0
        SUBB A, #0
        JC L_main9
        DEC _counter+0
L_main9:
;dec2bcd2ssd.c,26 ::                 }
L_main6:
;dec2bcd2ssd.c,28 ::                 bcd = Dec2Bcd(counter);
        MOV FARG_Dec2Bcd_dec+0, _counter+0
        LCALL _Dec2Bcd+0
        MOV _bcd+0, 0
;dec2bcd2ssd.c,29 ::                 bcdU = (bcd & 0x0F) << 4;
        MOV A, R0
        ANL A, #15
        MOV R2, A
        MOV R1, #4
        MOV A, R2
        INC R1
        SJMP L__main12
L__main13:
        CLR C
        RLC A
L__main12:
        DJNZ R1, L__main13
        MOV R3, A
        MOV _bcdU+0, 3
;dec2bcd2ssd.c,30 ::                 bcdL = bcd >> 4;
        MOV R2, #4
        MOV A, R0
        INC R2
        SJMP L__main14
L__main15:
        CLR C
        RRC A
L__main14:
        DJNZ R2, L__main15
        MOV R1, A
        MOV _bcdL+0, 1
;dec2bcd2ssd.c,31 ::                 P3 = bcdU | bcdL;
        MOV A, R3
        ORL A, R1
        MOV P3+0, A
;dec2bcd2ssd.c,32 ::                 }
        LJMP L_main0
;dec2bcd2ssd.c,33 ::                 }
        SJMP #254
; end of _main
List file
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
;  LST file generated by mikroListExporter - v.2.0
; Date/Time: 3/4/2015 12:52:34 AM
;Address Opcode     ASM
0x0000  0x02004D    LJMP 77
0x0003  0x020000    LJMP 0
0x0006  0x00        NOP
0x0007  0x00        NOP
0x0008  0x00        NOP
0x0009  0x00        NOP
0x000A  0x00        NOP
0x000B  0x020000    LJMP 0
0x000E  0x00        NOP
0x000F  0x00        NOP
0x0010  0x00        NOP
0x0011  0x00        NOP
0x0012  0x00        NOP
0x0013  0x020000    LJMP 0
0x0016  0x00        NOP
0x0017  0x00        NOP
0x0018  0x00        NOP
0x0019  0x00        NOP
0x001A  0x00        NOP
0x001B  0x020000    LJMP 0
0x001E  0x00        NOP
0x001F  0x00        NOP
0x0020  0x00        NOP
0x0021  0x00        NOP
0x0022  0x00        NOP
0x0023  0x020000    LJMP 0
_Dec2Bcd:
0x0026  0x75F00A    MOV B, #10
0x0029  0xE508      MOV A, FARG_Dec2Bcd_dec
0x002B  0x84        DIV AB
0x002C  0xFA        MOV R2, A
0x002D  0x7804      MOV R0, #4
0x002F  0xEA        MOV A, R2
0x0030  0x08        INC R0
0x0031  0x8002      SJMP L__Dec2Bcd10
L__Dec2Bcd11:
0x0033  0xC3        CLR C
0x0034  0x33        RLC A
L__Dec2Bcd10:
0x0035  0xD8FC      DJNZ R0, L__Dec2Bcd11
0x0037  0xF9        MOV R1, A
0x0038  0x75F00A    MOV B, #10
0x003B  0xE508      MOV A, FARG_Dec2Bcd_dec
0x003D  0x84        DIV AB
0x003E  0xE5F0      MOV A, B
0x0040  0xF8        MOV R0, A
0x0041  0xE9        MOV A, R1
0x0042  0x4200      ORL R0, A
0x0044  0x22        RET
; end of _Dec2Bcd
___CC2D:
;__Lib_System.c,13 ::
;__Lib_System.c,15 ::
_CC2D_Loop1:
;__Lib_System.c,16 ::
0x0045  0xE4        CLR A
;__Lib_System.c,17 ::
0x0046  0x93        MOVC A, @A+DPTR
;__Lib_System.c,18 ::
0x0047  0xF6        MOV @R0, A
;__Lib_System.c,19 ::
0x0048  0x08        INC R0
;__Lib_System.c,20 ::
0x0049  0xA3        INC DPTR
;__Lib_System.c,21 ::
0x004A  0xD9F9      DJNZ R1, _CC2D_Loop1
;__Lib_System.c,23 ::
0x004C  0x22        RET
; end of ___CC2D
_main:
0x004D  0x758134    MOV SP, #52
0x0050  0x1200C5    LCALL 197
0x0053  0x758000    MOV P0, #0
0x0056  0x759000    MOV P1, #0
0x0059  0x75A003    MOV P2, #3
0x005C  0x75B000    MOV P3, #0
L_main0:
0x005F  0x20A016    JB P2_0_bit, L_main2
0x0062  0x7E36      MOV R6, 54
0x0064  0x7FC9      MOV R7, 201
0x0066  0xDFFE      DJNZ R7, PC-2
0x0068  0xDEFC      DJNZ R6, PC-4
L_main3:
0x006A  0x20A002    JB P2_0_bit, L_main4
0x006D  0x80FB      SJMP L_main3
L_main4:
0x006F  0xC3        CLR C
0x0070  0xE533      MOV A, _counter
0x0072  0x9463      SUBB A, #99
0x0074  0x5002      JNC L_main5
0x0076  0x0533      INC _counter
L_main5:
L_main2:
0x0078  0x20A116    JB P2_1_bit, L_main6
0x007B  0x7E36      MOV R6, 54
0x007D  0x7FC9      MOV R7, 201
0x007F  0xDFFE      DJNZ R7, PC-2
0x0081  0xDEFC      DJNZ R6, PC-4
L_main7:
0x0083  0x20A102    JB P2_1_bit, L_main8
0x0086  0x80FB      SJMP L_main7
L_main8:
0x0088  0xD3        SETB C
0x0089  0xE533      MOV A, _counter
0x008B  0x9400      SUBB A, #0
0x008D  0x4002      JC L_main9
0x008F  0x1533      DEC _counter
L_main9:
L_main6:
0x0091  0x853308    MOV FARG_Dec2Bcd_dec, _counter+0
0x0094  0x1126      ACALL _Dec2Bcd
0x0096  0x850032    MOV _bcd, 0
0x0099  0xE8        MOV A, R0
0x009A  0x540F      ANL A, #15
0x009C  0xFA        MOV R2, A
0x009D  0x7904      MOV R1, #4
0x009F  0xEA        MOV A, R2
0x00A0  0x09        INC R1
0x00A1  0x8002      SJMP L__main12
L__main13:
0x00A3  0xC3        CLR C
0x00A4  0x33        RLC A
L__main12:
0x00A5  0xD9FC      DJNZ R1, L__main13
0x00A7  0xFB        MOV R3, A
0x00A8  0x850331    MOV _bcdU, 3
0x00AB  0x7A04      MOV R2, #4
0x00AD  0xE8        MOV A, R0
0x00AE  0x0A        INC R2
0x00AF  0x8002      SJMP L__main14
L__main15:
0x00B1  0xC3        CLR C
0x00B2  0x13        RRC A
L__main14:
0x00B3  0xDAFC      DJNZ R2, L__main15
0x00B5  0xF9        MOV R1, A
0x00B6  0x850130    MOV _bcdL, 1
0x00B9  0xEB        MOV A, R3
0x00BA  0x49        ORL A, R1
0x00BB  0xF5B0      MOV P3, A
0x00BD  0x015F      AJMP L_main0
0x00BF  0x80FE      SJMP #254
; end of _main
0x00C5  0x7830      MOV R0, 48
0x00C7  0x7904      MOV R1, 4
0x00C9  0x7582C1    MOV DP0L, 193
0x00CC  0x758300    MOV DP0H, 0
0x00CF  0x120045    LCALL 69
0x00D2  0x22        RET
;dec2bcd2ssd.c,0 :: ?ICS_bcdL
0x00C1  0x00 ;?ICS_bcdL+0
; end of ?ICS_bcdL
;dec2bcd2ssd.c,0 :: ?ICS_bcdU
0x00C2  0x00 ;?ICS_bcdU+0
; end of ?ICS_bcdU
0x00C3  0x00 ;?ICS_bcd+0
; end of ?ICS_bcd
;dec2bcd2ssd.c,0 :: ?ICS_counter
0x00C4  0x00 ;?ICS_counter+0
; end of ?ICS_counter
Symbol List:
//** Routines locations **
//ADDRESS    SIZE    PROCEDURE
0x0026      [31]    _Dec2Bcd
0x0045       [8]    ___CC2D
0x004D     [116]    _main
//** Variables locations **
//ADDRESS    SIZE    VARIABLE
0x0000       [1]    R0
0x0001       [1]    R1
0x0002       [1]    R2
0x0003       [1]    R3
0x0004       [1]    R4
0x0005       [1]    R5
0x0006       [1]    R6
0x0007       [1]    R7
0x0008       [1]    FARG_Dec2Bcd_dec
0x0030       [1]    _bcdL
0x0031       [1]    _bcdU
0x0032       [1]    _bcd
0x0033       [1]    _counter
0x0080       [1]    P0
0x0081       [1]    SP
0x0082       [1]    DPL
0x0083       [1]    DPH
0x0090       [1]    P1
0x00A0       [1]    P2
0x00A0       [0]    P2_1_bit
0x00A0       [0]    P2_0_bit
0x00B0       [1]    P3
0x00D0       [1]    PSW
0x00E0       [1]    ACC
0x00F0       [1]    B
//** Constants locations **
//ADDRESS    SIZE    CONSTANT
0x00C1       [1]    ?ICS_bcdL
0x00C2       [1]    ?ICS_bcdU
0x00C3       [1]    ?ICS_bcd
0x00C4       [1]    ?ICS_counter
//** Label List: **
  L_main0
  L_main1
  L_main2
  L_main3
  L_main4
  L_main5
  L_main6
  L_main7
  L_main8
  L_main9
  _Dec2Bcd
  L__Dec2Bcd10
  L__Dec2Bcd11
  _main
  L__main12
  L__main13
  L__main14
  L__main15
  _CC2D_Loop1
  _CC2PD_Loop1
  _CC2XD_Loop1
  ___DoIFC
  ___CC2D
  ___CC2PD
  ___CC2XD
  • Dec2Bcd2Ssd.rar
  • Decimal2Bcd27Segment.rar
BCD: Mov A,Mynumber
MOV B,#10
DIV AB
MOV R3,A
MOV A,B
SWAP A
MOV P2,A
Ret
thank you it really work well
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
void main() {
    P0 = 0x00;
    P1 = 0x00;
    P2 = 0x03;
    P3 = 0x00;
    while(1) {
          if(!P2_0_bit) {
             Delay_ms(30);
             while(!P2_0_bit);
          if(!P2_1_bit) {
             Delay_ms(30);
             while(!P2_1_bit);
          bcdL = bcd >> 4;
          P3 = bcdU | bcdL;
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
_Dec2Bcd:
        MOV B+0, #10
        DIV AB
        MOV R2, A
        MOV R0, #4
        MOV A, R2
        INC R0
        SJMP L__Dec2Bcd10
L__Dec2Bcd11:
        CLR C
        RLC A
L__Dec2Bcd10:
        MOV R1, A
        MOV B+0, #10
        DIV AB
        MOV A, B+0
        MOV R0, A
        MOV A, R1
        ORL 0, A
        RET
; end of _Dec2Bcd
_main:
        MOV SP+0, #128
        MOV P0+0, #0
        MOV P1+0, #0
        MOV P2+0, #3
        MOV P3+0, #0
L_main0:
        NOP
        MOV R6, 54
        MOV R7, 201
        DJNZ R7,
        DJNZ R6,
L_main3:
        NOP
        SJMP L_main3
L_main4:
        CLR C
        MOV A, _counter+0
        SUBB A, #99
        JNC L_main5
        INC _counter+0
L_main5:
L_main2:
        NOP
        MOV R6, 54
        MOV R7, 201
        DJNZ R7,
        DJNZ R6,
L_main7:
        NOP
        SJMP L_main7
L_main8:
        SETB C
        MOV A, _counter+0
        SUBB A, #0
        JC L_main9
        DEC _counter+0
L_main9:
L_main6:
        LCALL _Dec2Bcd+0
        MOV _bcd+0, 0
        MOV A, R0
        ANL A, #15
        MOV R2, A
        MOV R1, #4
        MOV A, R2
        INC R1
        SJMP L__main12
L__main13:
        CLR C
        RLC A
L__main12:
        DJNZ R1, L__main13
        MOV R3, A
        MOV _bcdU+0, 3
        MOV R2, #4
        MOV A, R0
        INC R2
        SJMP L__main14
L__main15:
        CLR C
        RRC A
L__main14:
        DJNZ R2, L__main15
        MOV R1, A
        MOV _bcdL+0, 1
        MOV A, R3
        ORL A, R1
        MOV P3+0, A
        LJMP L_main0
        SJMP #254
; end of _main
List file
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
;Address Opcode     ASM
0x0006  0x00        NOP
0x0007  0x00        NOP
0x0008  0x00        NOP
0x0009  0x00        NOP
0x000A  0x00        NOP
0x000E  0x00        NOP
0x000F  0x00        NOP
0x0010  0x00        NOP
0x0011  0x00        NOP
0x0012  0x00        NOP
0x0016  0x00        NOP
0x0017  0x00        NOP
0x0018  0x00        NOP
0x0019  0x00        NOP
0x001A  0x00        NOP
0x001E  0x00        NOP
0x001F  0x00        NOP
0x0020  0x00        NOP
0x0021  0x00        NOP
0x0022  0x00        NOP
_Dec2Bcd:
0x002B  0x84        DIV AB
0x0030  0x08        INC R0
L__Dec2Bcd11:
0x0033  0xC3        CLR C
0x0034  0x33        RLC A
L__Dec2Bcd10:
0x003D  0x84        DIV AB
0x0044  0x22        RET
; end of _Dec2Bcd
___CC2D:
_CC2D_Loop1:
0x0045  0xE4        CLR A
0x0048  0x08        INC R0
0x004C  0x22        RET
; end of ___CC2D
_main:
L_main0:
L_main3:
L_main4:
0x006F  0xC3        CLR C
L_main5:
L_main2:
L_main7:
L_main8:
0x0088  0xD3        SETB C
L_main9:
L_main6:
0x00A0  0x09        INC R1
L__main13:
0x00A3  0xC3        CLR C
0x00A4  0x33        RLC A
L__main12:
0x00AE  0x0A        INC R2
L__main15:
0x00B1  0xC3        CLR C
0x00B2  0x13        RRC A
L__main14:
; end of _main
0x00D2  0x22        RET
; end of ?ICS_bcdL
; end of ?ICS_bcdU
; end of ?ICS_bcd
Symbol List:
0x0045       [8]    ___CC2D
0x004D     [116]    _main
0x0000       [1]    R0
0x0001       [1]    R1
0x0002       [1]    R2
0x0003       [1]    R3
0x0004       [1]    R4
0x0005       [1]    R5
0x0006       [1]    R6
0x0007       [1]    R7
0x0030       [1]    _bcdL
0x0031       [1]    _bcdU
0x0032       [1]    _bcd
0x0033       [1]    _counter
0x0080       [1]    P0
0x0081       [1]    SP
0x0082       [1]    DPL
0x0083       [1]    DPH
0x0090       [1]    P1
0x00A0       [1]    P2
0x00A0       [0]    P2_1_bit
0x00A0       [0]    P2_0_bit
0x00B0       [1]    P3
0x00D0       [1]    PSW
0x00E0       [1]    ACC
0x00F0       [1]    B
0x00C3       [1]    ?ICS_bcd
//** Label List: **
  L_main0
  L_main1
  L_main2
  L_main3
  L_main4
  L_main5
  L_main6
  L_main7
  L_main8
  L_main9
  _Dec2Bcd
  L__Dec2Bcd10
  L__Dec2Bcd11
  _main
  L__main12
  L__main13
  L__main14
  L__main15
  _CC2D_Loop1
  _CC2PD_Loop1
  _CC2XD_Loop1
  ___DoIFC
  ___CC2D
  ___CC2PD
  ___CC2XD
thank i understand well
