How to send two ADC value via ARDUINO?
nishat anjum khan
for my project i have to send two adc value and then have to plot it individually in MATLAB...can anyone give me suggestion that how can i send two ADC value via ARDUINO?
Re: arduino uno_ two adc
You have to use ADC and Serial library.
can u give me some example about how to multiplex ADC in Arduino?
what is your connection? usb serial parallel?
Code C - [expand]
ADMUX = x;
where x is adc channel
Here is the code. See attached files.
Code C++ - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
int analogPin1 = 0;     // potentiometer wiper (middle terminal) connected to analog pin 0
                       // outside leads to ground and +5V
int analogPin2 = 1;     // potentiometer wiper (middle terminal) connected to analog pin 1
int val = 0;           // variable to store the value read
void setup()
  Serial.begin(9600);          //  setup serial 9600 bps baudrate
void loop()
  val = analogRead(analogPin1);    // read the input pin
  Serial.println(val);             // debug value
  delay(500);
  val = analogRead(analogPin2);    // read the input pin
  delay(500);
  • UNO.rar
Hi
Would be good if you could let me know of a safe link to download the Arduino Uno Library for Proteus.
Seems there are a few links when you google but don't know which ones are safe and actually work .
thanks
Hi Milan
Have loaded it in without any problems, well get some .hex loaded up tomorrow and give it a good test; will save me having to drag the dev board out all the time.
Many thanks
thank u...it helps me a lot...can u just tell me how i create two y axis in MATLAB without using plotyy function?
Hi
I can't help you with Matlab.
