how to select a diode from its datasheet specs
mtawab74
Member level 3
how to select the diode
Dear All
I have SMPS where the ouput current is a triangle with peak 20 A
and a duty cycle 30%
I have a diodes where its datasheet says that its non-repetative peak is 50A and it'smaximum average is 12 A
i wounder if this diode will work with the SMPS
i just ask abt current rating ( i know about switching speed problems and i took it mind)
how to select rating of diode
What is the average forward current in your design?
If it is in range with the selected diode you can use it.
Consider the max reverse voltage.
how to select a diode?
how about topology of smps.
if it is flyback,I think this diode is safty for you application.
I think we should select a diode with average rating that's larger than the peak current in our application
so if we have a triangle current with peak 20A 30% duty cyle ( average = 3 A ) then we should select a diode with average rating > 20 A
IS THAT TRUE ???????????
