2cent
Hi all,
I'm new in microwave and antenna field...
now I'm learning to design a circular polarize antenna...
what I've learn so far is CP will generate for instance if there is a 2 component of the same magnitude but different 90 degrees in phase.
The simple is by using two identical antenna but located one in horizontal and other in vertical.
My professor want me to understand the phenomena that occurs when the CP is generated. So I design 2 dipole antenna and I'm using IE3D for the simulation.
I know I can read the Axial ratio value from the IE3D, but I want to know the magnitude and phase different that occurs between the two antenna.
So the question is other than the Axial Ratio parameter, can I see the magnitude and the phase current (the two main subject of generating CP) visibly using IE3D?
If it possible please explain it to me, if not please give me another advice.
Sorry if it's annoying, but I've read the CP theory and now I want to understand what it looks like in the simulation results, how I can figure it have same magnitude or have 90 degree phase different.
Thanks for the help.
Andrew
Andrew
